B16A Tranny problems!!!!!!!!
I have a 92 hatch with a jdm B16A engine with 38k miles.I bought the car like a month ago and the tranny was acting up.The tranny have a exedy stage 2 clutch and a stock flywheel.The clutch pedal was really low like if i lift the clutch pedal like 1/2 inch the car would start moving.It was really hard to get it on first and on reverse.So i got another tranny with 40k out of a 00 si with the same clutch and the tranny is doing the same thing.I was thinking the clutch is bad but the clutch has 5k miles so im lost.Can some on help me on this?Thanx.
Rick
Modified by Rickcrx at 9:01 PM 4/19/2006
Rick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickcrx »</TD></TR><TR><TD CLASS="quote">I have a 92 hatch with a jdm B16A engine with 38k miles.I bought the car like a month ago and the tranny was acting up.The tranny have a exedy stage 2 clutch and a stock flywheel.The clutch pedal was really low like if i lift the clutch pedal like 1/2 inch the car would start moving.It was really hard to get it on first and on reverse.So i got another tranny with 40k out of a 00 si with the same clutch and the tranny is doing the same thing.I was thinking the clutch is bad but the clutch has 5k miles so im lost.Can some on help me on this?Thanx.
Rick
Modified by Rickcrx at 9:01 PM 4/19/2006</TD></TR></TABLE>
hmm did u try bleeding it again? maybe check if your slave cylinder and clutch master is still good. sounds like a hydrolic pressure thing.
Rick
Well id bleed the tranny and still the same.I have no leaks from the master cylender so my last choice is the clutch.They guy before me used to beat the **** out of this car and he also lied to me about a bunch of **** in the car so im goin to buy another clutch and see what happen.Btw where i can find a good clutch for about $300?
CimorelliCRX
Dec 15, 2002 04:02 AM
