Help Converting 9005 to Low Beam
Old Apr 7, 2002 | 05:27 PM
IgniteTeg's Avatar
Default Help Converting 9005 to Low Beam
I know how to do this but my question is how the hell do you remove those 2 notches. I have no access to a grinder or anything type of chisel tool. So what other stuff can I use to be able to remove the 2 notches inside the and shave off the outside???? I have tried using a nail filer and it doesn't work either Thanks for any help.
Old Apr 7, 2002 | 09:07 PM
six_speed's Avatar
Default Re: Help Converting 9005 to Low Beam (IgniteTeg)
got some nail cutter?
those work wonderfuly well, should try it.
remember there are different style the long one and the folding one.
the folding obviously does not work. Only the long one w/ a small head to make the clerance to cut the two plastic thingy in the middle.
go nuts
Old Apr 7, 2002 | 11:47 PM
IgniteTeg's Avatar
Default Re: Help Converting 9005 to Low Beam (Lilmumbler)
Hehe no I don't have any sort of tools like that also. Is there anything else that would do it with ease without spending that much money???? Cuz this is just only a one timer I don't want to spend on something that I won't use often. Thanks for your help and any other help.
Old Apr 8, 2002 | 09:55 AM
six_speed's Avatar
u mean u dont have a toe nail cutter? whoa? hehehe
i'm assuming u dont cut ur nails then eh??
lol
othere then the nail cutter thingy, i dont know what will be good enuff to cut those 2 plastic thingy?.
go to a nail shop and buy 1?
3-6 buck?
hheheh just a suggestion.
Old Apr 8, 2002 | 10:51 AM
IgniteTeg's Avatar
Lol no, what I meant was I only have the folding nail cutter. I guess I gotta go look for the long one don't even know how it look. All the nail cutter I see and have used are just the folding one. Thanks for your help.
Old Apr 8, 2002 | 10:52 AM
bps2799's Avatar
Go buy an X-acto knife for $5.
Old Apr 8, 2002 | 11:50 AM
reefer_bob's Avatar
Default Re: Help Converting 9005 to Low Beam (bps2799)
Old Apr 8, 2002 | 12:05 PM
IgniteTeg's Avatar
Default Re: Help Converting 9005 to Low Beam (reefer_bob)
hm i'l try that hope it can remove the 2 guilde notches inside. Thanks for the help.
Old Apr 8, 2002 | 12:44 PM
reefer_bob's Avatar
I actually use a generic utility (stanley) knife.. rather than actually trying to cut it, stick the blade in there and kinda pry with it against the side housing... Worked the best for me!
Old Apr 8, 2002 | 01:48 PM
bps2799's Avatar
I have the X-acto knife deluxe $15 set that has a chisel type blade insert which worked beautifully.
Old Jul 5, 2002 | 05:08 PM
WOTTEG's Avatar
I have used my girlfriend's mother's Dremmel so many times this year, I consider it adopted.
Sure does make EVERY project seem easier. Plus it's FREE!
My recommendation: get a girlfriend, raid her parent's garage when you need stuff.
Old Jul 5, 2002 | 10:57 PM
IgniteTeg's Avatar
Default Re: Help Converting 9005 to Low Beam (WOTTEG)
Haha lolz
ssbpDC2
Jan 21, 2011 09:44 PM
NSfit
Aug 20, 2006 12:27 PM
fe519
Sep 14, 2004 01:45 PM
94TealGSR
Jan 16, 2003 09:14 PM
IgniteTeg
Apr 5, 2002 05:39 PM
