98 civic check engine light cat convtr problem
Old Apr 19, 2006 | 02:38 PM
hobo79's Avatar
New User
Default 98 civic check engine light cat convtr problem
Ok, i have a 98 civic ex coupe and I have a check engine light, had it checked out and its throwing a code for cat convtr..........i am curious whether i can get an aftermarket cat convtr and solve the problem passing emissions?........
http://cgi.ebay.com/ebaymotors...QrdZ1
Old Apr 19, 2006 | 04:47 PM
thesmogman's Avatar
Default Re: 98 civic check engine light cat convtr problem (hobo79)
It could be the cat. But it is the secondary O2 sensor that is telling the computer that the cat is bad.
What I am saying is it could be the secondary O2 sensor.
It is cheaper than a cat.
Also check with your H dealer some emissions related components might be covered under warranty.
Old Apr 19, 2006 | 08:22 PM
Chiovnidca's Avatar
Default Re: 98 civic check engine light cat convtr problem (thesmogman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman &raquo;</TD></TR><TR><TD CLASS="quote">
Not likely, if it has a p0420 it probably has a bad cat.
Also check with your H dealer some emissions related components might be covered under warranty.</TD></TR></TABLE>
8 years or 80000 miles.
Old Apr 19, 2006 | 09:16 PM
hobo79's Avatar
New User
Default Re: 98 civic check engine light cat convtr problem (Chiovnidca)
yes it threw a p0420 code............so can i pass emissions by getting an aftermarket cat like the one above on ebay?........rather spend $50-$100 on aftermarket one that can pass emissions vs OEM for an arm and leg.
Old Apr 19, 2006 | 10:26 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hobo79 &raquo;</TD></TR><TR><TD CLASS="quote">yes it threw a p0420 code............so can i pass emissions by getting an aftermarket cat like the one above on ebay?........rather spend $50-$100 on aftermarket one that can pass emissions vs OEM for an arm and leg.</TD></TR></TABLE>
We haven't had any luck with a/m cats, they dont seem to last very long. But i've heard from others that some work well, haven't heard a brand name though.
Old Apr 20, 2006 | 08:06 AM
hobo79's Avatar
New User
Ok, got a deal from my mechanic......got one that can pass emissions for $235 installed. Sounds good to me
but on the downside, i did lots of maintainence to the car.
rotors needed to be replaced (brembo) $150
brake pads $105
wheel bearing ($50 each) $100
hub $150
cat cnvt $235
driver side window weather stripping $10
oil change $20
Total damage is $770
plus labor $200
$970 out the door
Old Apr 20, 2006 | 02:37 PM
hobo79's Avatar
New User
ugh.......just got the car but, it's running good, but now its throwing a misfiring code. =/
so I will have to bring it back in the shop on saturday. hopefully wont have to pay anymore........ can a spark plug change cure this?
strider380
Apr 30, 2011 05:56 PM
bichgsr
Apr 10, 2008 08:30 PM
BrokenBack
Jul 9, 2006 11:12 PM
Melman872
Nov 29, 2005 08:54 AM
onyx00
Jul 31, 2004 09:38 AM
