HELP... engine question reall simple
Old Apr 19, 2006 | 12:39 PM
rickgiblin's Avatar
Default HELP... engine question reall simple
ok, well i recently blew my engine and found a nother one. my stock one that i blew was a d16y8. the one that im looking at getting is a d16y7. will i have to change the computer and all that stuff or will i be able to hook it up and not have to change anything? can someone please help me. or does anyone know where a d16y8 is for sale... i need a engine
Modified by rickgiblin at 2:36 PM 4/19/2006
Old Apr 19, 2006 | 12:45 PM
EX-T's Avatar
Default Re: HELP... engine question reall simple (rickgiblin)
Your original motor was an SOHC VTEC engine. The y7 is a SOHC non VTEC engine. I'm not sure if you'll need a new ecu or not but more than likely you will.
Old Apr 19, 2006 | 12:48 PM
Syndacate's Avatar
I think there's a mod u can do to ur ECU to change a stock P28 to see if it does vtec or not, somebody else that knows ECU's will have to tell you for sure tho
Old Apr 19, 2006 | 12:52 PM
jays93eg6's Avatar
Your stock engine is a 1.6L SOHC Vtec. I suggest you look for another Y8 motor. That motor is pretty easy to find. I personally would not swap a Y8 for a Y7 motor, but thats just me.
Old Apr 19, 2006 | 12:56 PM
schardbody's Avatar
if your bottom end is all thats messed up, just put the old head, IM, TB, dizzy, and harness onto the new motor, and use the stock ecu. that would be the easiest way to do it. other than that you would need a differanct ecu. it wouldnt be hard to just swap the new one in, but you will be losing HP
Old Apr 19, 2006 | 01:02 PM
EX-T's Avatar
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">I think there's a mod u can do to ur ECU to change a stock P28 to see if it does vtec or not, somebody else that knows ECU's will have to tell you for sure tho</TD></TR></TABLE>
It's not a p28, it's a p2p. The p28 is for the d16z6!
Old Apr 19, 2006 | 01:36 PM
rickgiblin's Avatar
does anyone know where a d16y8 engine is around ga or a site on the net with them?
96ex-v
Jan 18, 2010 11:50 PM
munky_350
May 21, 2009 11:46 AM
CALIGUYCRX
May 20, 2008 12:28 PM
B18cteg
12
May 26, 2003 03:10 PM
Irishweird00
Mar 3, 2003 07:11 AM
