COOLING PROBLEMS AND IDLE PROBLEMS SINCE SKUNK2 IM INSTALL and CEL 43
Old Apr 19, 2006 | 11:29 AM
SIHATCHBACK's Avatar
Default COOLING PROBLEMS AND IDLE PROBLEMS SINCE SKUNK2 IM INSTALL and CEL 43
i have 95 integra Ls with LS motor with CTR pistons crower valve spring retainers, crower stage 3 cams p&p head i recently installed skunk2 manifold before previous owner had problems with radiators busting and over heating and idling problem now i have and i changed throttle body gasket and intake manifold gasket now i have the problem, the car has gude ECU it idles sometimes at 500 then the rest is at 3k but with the stock computer it idle irratically from 1k to 2k like it low on coolant, it throws a CEL for code 43 any help apprecited in advance? ive been throung all my vacum lines and all are correct i bleed cooling system as well
z6sedan
30
Jan 23, 2016 03:57 PM
sh4mr0ck
Jul 7, 2010 12:15 PM
Ep1dem1c
Jul 8, 2007 07:55 PM
oldskoolGSR
May 8, 2003 04:21 PM
AmauryR
Jan 5, 2003 08:50 PM
