Engine fit question
Old Apr 19, 2006 | 08:49 AM
KillerElfboy's Avatar
Default Engine fit question
on a 92 ex, it comes with the f22a6, will a f22a4 fit? also will the decrease in hp be that much noticeable?
Old Apr 19, 2006 | 09:02 AM
92accordexpower's Avatar
Default Re: Engine fit question (KillerElfboy)
yes it will fit, i put an f22a1 into my 92 ex, but i swapped manifolds to minimize HP loss. you'll only lose about 10c-hp.
but yea it'll fit no problem.
Old Apr 19, 2006 | 11:39 AM
Default Re: Engine fit question (92accordexpower)
i know the EX is heavier, will this be a significant loss in HP? will my mileage change at all?
i dont know about doing mods or not, its a decent car but the heat/cold doesnt work neither the AC nor the power locks
perhaps i'll sell it
Old Apr 19, 2006 | 01:34 PM
i_kick_turtles's Avatar
They are the same engine with a few differences. When you change engines, just keep your EX 4-2-1 exhaust manifold, dual runner intake manifold, and ecu. You won't lose any power this way.
Old Apr 19, 2006 | 03:06 PM
Default Re: Engine fit question (I R Tylor)
well on the f22a6 that is ruined the timing belt snapped and bitch slappped my engine, will those parts be salvageable with the kinda damage i had?
im having a shop put it in, if i tell them i want those parts transferred, think they do it??
Modified by KillerElfboy at 8:12 PM 4/19/2006
Old Apr 19, 2006 | 07:45 PM
wait the ecu should be fine, but what about the other two parts?
Old Apr 20, 2006 | 05:32 AM
notoriousB's Avatar
they'll be fine as well
Old Apr 20, 2006 | 06:04 AM
TouringAccord's Avatar
H-T Order of Merit
I thought the profile of the cam from the A6 was different than the A4 as well. IDK, I may be way off there, thought I remembered reading that somewhere (maybe on CB7Tuner).
The other parts will be fine to swap as well.
Old Apr 20, 2006 | 11:58 AM
cats_on_ice's Avatar
Default Re: Engine fit question (TouringAccord)
You're right, the cam is different on the A6. I believe it's the only difference between the A4 and the A6...but I'm ignorant
Old Apr 20, 2006 | 09:09 PM
Default Re: Engine fit question (cats_on_ice)
nah i think you're right, i know theree isnt much of a diff just a more efficient (better hp) something air flow or other
Old Apr 20, 2006 | 10:16 PM
those other parts, manifold, etc.
will the shop do that for me if i ask them? also is it possible that those parts could be damaged???, cuz they might try and tell me they are no good and then my a6 will end up parted out on ebay
i gota nice deal on the a4, its got about 130k on it but the guy put in a t -belt and is even sending the receipt belt along with the engine, not bad for 500 shipped, he said it looks like it had a tune up or refurbish job something or other. But i just want to get this thing going,
oh yea, will the 92 ex wheels, and those three parts fit on a 91 DX(f22a1)?
Modified by KillerElfboy at 4:34 AM 4/21/2006
Old Apr 21, 2006 | 04:19 AM
H-T Order of Merit
yes, the mechanic should do it if you ask, it's pretty simple while the motor is out. If not, just take the parts off yourself and do the work yourself, should take more than an afternoon or so to swap those parts.
No, the parts aren't messed up. No way could the intake or exhaust manifolds get messed up from the timing belt breaking. I highly doubt you would have damaged the camshaft either, I mean your pistons would have had to drive your valves back real hard to even possibly cause damage to the cam, but I could be wrong. I would think the valves would just bend before damaging the cam.
You should have no problem swapping those three parts onto either the F22A4 motor your getting as a replacement or your F22A1 in the other car. Pretty much everything is swappable between the F22A1, F22A4 and F22A6 as far as I know.
As for the rims, any rims from the 90-97 Accords and 98-02 4cyl Accords will work just fine on either of your Accords.
If your planning on selling one of your Accords, put the F22A6 parts and rims of your choice onto the car your keeping and then put the other parts on the other car your selling.
Old Apr 21, 2006 | 09:28 AM
yea, im prob gonna have the most 'EX' looking DX out there
b0yg0tskills
Honda Civic (2001 - 2005)
Jan 29, 2007 02:14 PM
ThinHoanG
Feb 13, 2005 12:09 AM
blkknight619
Feb 7, 2005 12:08 PM
Turb0Minnow
Jun 14, 2002 06:32 PM
