JDM type R cams in stock b-16 head
Old Apr 19, 2006 | 07:49 AM
TreeToTall's Avatar
Default JDM type R cams in stock b-16 head
I have a Greddy 18G turbo with a stock b16 head. I was wondering if my stock head could use JDM b18c cams safely or would they be to aggressive? What would be my rev limit?
Old Apr 19, 2006 | 08:03 AM
slodel's Avatar
Default Re: JDM type R cams in stock b-16 head (TreeToTall)
use them
rev limit=2000000000
whats your computer at duh
Old Apr 19, 2006 | 08:16 AM
98civicswapped's Avatar
Default Re: JDM type R cams in stock b-16 head (slodel)
bump
Old Apr 19, 2006 | 08:39 AM
turbotime's Avatar
yeah u can, you dont need upgraded springs and retainers but its recommended.
Also you will need a retune to get the power out of them.
They are better thant eh b16 cams, and gsr cams.
Old Apr 19, 2006 | 08:49 AM
atec's Avatar
Default Re: (turbotime)
you need springs and retainers if you raise the stock b16 rev limit, As you should since your engine is going to make more top end power than before.
seems like the itr cams will make more power all around when properly tuned.
Old Apr 19, 2006 | 01:11 PM
TreeToTall's Avatar
ok, thanks guys just one more question. If I were to upgrade valve springs and retainers with set would be best for a 8500 rev? I was thinking ITR inner and outer intake valve springs and portflow TI ( or ITR retainers ) for the exhaust side and leaving the intake valve spring on my b16 alone.
Modified by TreeToTall at 7:22 PM 4/19/2006
Old Apr 19, 2006 | 06:23 PM
TreeToTall's Avatar
bump
Old Apr 19, 2006 | 06:33 PM
99TurboEM1's Avatar
Supertech makes some of the best valvetrain components... Well worth the money...
Laz's EP
Sep 19, 2010 08:22 PM
93egSLEEPER
11
Dec 22, 2009 12:28 AM
AJxr
Jul 10, 2009 09:45 PM
LSVtechnologytur...
Jan 26, 2007 02:44 PM
charjacq
Sep 29, 2002 09:07 AM
