CEL came on when RPM's > 5000??
Old Apr 19, 2006 | 06:50 AM
nosegrindR's Avatar
Default CEL came on when RPM's > 5000??
Hello H-T
I have a 1996 GS-R, bone stock.
Last night I was driving and the CEL light came on when I my rpm's went over 5000, normally I would hear VTEC 'kick in', but this time the light came on instead. The VTEC 'sound' did kick in, but i quickly took my foot off the throttle once i saw the light come on.
I've searched HT for this problem, and I'll probably go check what error it's throwing later tonight, but i'm just wondering if any of you guys have had this problem, and if you did, how you rectified the problem.
Thanks a lot in advance guys
Old Apr 19, 2006 | 07:34 AM
otiosity's Avatar
Default Re: CEL came on when RPM's > 5000?? (nosegrindR)
If you go check, i am willing to bet that it will be code 22 or 23. Mine has done this a few times before when VTEC doesn't kick in, it will throw a code. It throws the code because it knows VTEC should be engaging, but it is not for some odd reason. Check your oil and make sure the car is at good operating temps, etc. hope this helps
Old Apr 19, 2006 | 09:20 AM
nosegrindR's Avatar
thanks for the quick reply, otiosity, i believe you're right as well. If this was the case, what steps should I take in order to turn the CEL light off?
Old Apr 19, 2006 | 09:47 AM
b17aprincess's Avatar
Default Re: (nosegrindR)
either take the car to autozone or some place they offer free code pulling, or disconnect your battery cable.
Old Apr 19, 2006 | 11:28 AM
nosegrindR's Avatar
Sounds good,
I'm in Canada so i dont have an autozone
Senbonzakura
Aug 27, 2006 01:16 AM
jdm stan
Aug 14, 2005 12:59 PM
ninety9ex
Jan 26, 2004 07:40 PM
boosted spoon
Jul 23, 2002 12:08 PM
Rhetoric
Jan 2, 2002 01:10 AM
