uh-oh, hydrolock.
Old Apr 7, 2002 | 03:38 PM
MK Ultra's Avatar
Default uh-oh, hydrolock.
Fortunately, I think it will be ok. I was at very low RPM (around 1700) when it happened. I was going up a hill and was almost at the top when my engine just stopped. Oh, and the road I was on had been choked down to one lane to facilitate what passes for "road construction" around here. Not exactly a good place to have your motor take a **** on you.
I was barely able to coast up to a side street (and block its single lane. Damn!). No way I can push it anywhere, it's all uphill and there's nowhere to push it to anyway. So I cringe and try turning the motor over. After about ten tries it catches and coughs itself into a rough idle. I observe what looks like steam blowing out the exhaust, but thankfully it's not the puffy, white clouds of coolant-tainted exhaust. It smooths out to a regular idle after running for thirty seconds or so, and the "steam" is no longer noticable. After that it seemed to run normally. I still can't help but wonder if I f'ed something up though.
This is the first time in nearly four years of having AEM intakes that anything remotely like this has happened to me. I've been pretty careful, always have the splash guards properly fitted, avoid driving through puddles, etc. But I think it's time for me to go back to the stock airbox.
Old Apr 7, 2002 | 03:53 PM
pleiades nutz's Avatar
Default Re: uh-oh, hydrolock. (MK Ultra)
My AEM's commin off ASAP....its been raining here alot lately and its just too much pain to worry about it figure the few hp increase is def not worth it.
Old Apr 8, 2002 | 02:48 PM
Muckman's Avatar
Moderator in Chief
Default Re: uh-oh, hydrolock. (nighthawkR618)
Ive had my AEM CAI on for almost 2 years without a bypass valve and Ive never had any problems. Unless your actually driving thro foot high puddles i dont think there should be a problem.
Old Apr 8, 2002 | 04:05 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: uh-oh, hydrolock. (Muckman)
that is really not true. You can suck up water in a good bit less than that. It's not like it takes a gallon of water to hydrolock a motor.
Do a compression check at least.
Old Apr 8, 2002 | 04:43 PM
B2FiNiTY's Avatar
How deep and high was the water?
Old Apr 8, 2002 | 05:16 PM
Big Phat R's Avatar
From what you wrote, it sounds like you got water in the AEM by going UP a hill?? How's that work?
Old Apr 8, 2002 | 05:23 PM
KooK's Avatar
Mustang Sally
Default Re: uh-oh, hydrolock. (Big Phat R)
.... Kinda makes me wonder if I should get one of those short intakes... thats scary man!
Old Apr 8, 2002 | 05:28 PM
Honda F1's Avatar
Default Re: uh-oh, hydrolock. (Maximanko)
Hey at worst you get a brand new engine courtesy of your respective insurance company.
Old Apr 8, 2002 | 07:26 PM
underrated99si's Avatar
Default Re: uh-oh, hydrolock. (HONDAF1)
Time for Comptech intake and IceBox
Old Apr 8, 2002 | 07:30 PM
Floyd's Avatar
Default Re: uh-oh, hydrolock. (underrated99si)
Ah, you failed to mention where the water was.
Old Apr 9, 2002 | 12:06 AM
MK Ultra's Avatar
Yes, I was going uphill. The road I was driving on was closed down to one lane. The right-side lane. Where all of the water flowing downhill was. The right side of the car just happens to be where the air filter is, of course, and I can only guess that I was getting enough water up there to cause my car to stall.
But I do not think now that it actually hydrolocked.
I did a compression check tonight, and I am in good shape. In fact, my engine seems pretty healthy, with only a 4% difference between the cylinder with the highest and the cylinder with the lowest readings.
djbrandonr
Dec 2, 2007 01:02 PM
A.E Motoring
Dec 18, 2006 05:17 PM
YellowR2000x2
May 22, 2005 02:04 AM
itrQ
Apr 28, 2002 03:55 PM
