Need some window help...
Old Apr 18, 2006 | 11:14 PM
'00Accordster's Avatar
Default Need some window help...
I've got a 2000 accord LX 4 cyl. for the past month and a half I've been having problems with the left rear window going up and down. Sometimes it works other times I can hear a click but the window just doesn't move.
I went back to the body shop I took it to a year ago when I had my accident in which the entire back end of my car was crushed in. He recommended WD-40. I used it but the problem is still there. I don't really trust the guy and was wondering what the problem might be so I can fix it myself.
Thanks guys!
Old Apr 19, 2006 | 02:13 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Need some window help... ('00Accordster)
Jump the motor.
Take off the door panel, find the window motor itself. There should be a two pin think gauge wire harness going in. Give it power and ground and see if it goes up or down. Do this a few times, and if it works fine, your problem is the interior wiring.
If its still messing up, you probably just need to grease the tracks or get a new power window regulator.
ewhittington82
Honda CR-V & Element
Sep 15, 2011 05:31 AM
juandaman
Sep 19, 2008 06:17 AM
'00Accordster
Apr 19, 2006 06:52 AM
'00Accordster
Apr 19, 2006 01:29 AM
5genhatch
Dec 19, 2004 11:20 AM
