D16z6...what turbo?
Old Apr 18, 2006 | 10:04 PM
1990hondaHF's Avatar
Default D16z6...what turbo?
I'd like to get a turbo that spools quick but also has power to redline....I read a lot about the t25/d16 combo, but some people say it stops making power after 5500+ RPM's while others still make power. I also read about t3's making lots of top end power but took a little longer to get going(again I focused on d16 fitment). ....My goal is 200"ish" HP....and the car would rarely get to the track to race....mostly in-town driving. Would a basic t25 or basic t3 be the best option? Thanks.
Old Apr 18, 2006 | 10:59 PM
LilCivic04's Avatar
Default Re: D16z6...what turbo? (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt &raquo;</TD></TR><TR><TD CLASS="quote">gt28r </TD></TR></TABLE>
Old Apr 18, 2006 | 11:02 PM
Stop the Beast's Avatar
Default Re: D16z6...what turbo? (1990hondaHF)
super 60 T3 or 28R should be perfect for you. Get a 28RS if you can afford it, or use a Mitsubishi 16g if you want a wonky inlet flange, but a cheap turbo.
Old Apr 19, 2006 | 05:18 AM
nerdsports's Avatar
for 200ish whp, a t3 42/48 will suit your needs. it'll pull to redline and spool up fast
or a t3 super 60 (it'll have a nicer top end).
most junkyard turbos (factory dsms and such) will achieve 200hp on a d16...
Old Apr 19, 2006 | 05:38 AM
nota-eg's Avatar
Default Re: (nerdsports)
I'm running a TD04 14G and I love it. Only Jesus blowing into the turbo could cause it to spool faster.
I managed a 13.7 w/ bad clutch and street tires.
For daily driving it kicks ***. Fast spool, it screams like a banshee, and the look on the faces of fat chicks in Monte Carlos as you blow by them is enough to make anyone smile.
Old Apr 19, 2006 | 09:10 AM
Default Re: (nota-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg &raquo;</TD></TR><TR><TD CLASS="quote">I'm running a TD04 14G and I love it.</TD></TR></TABLE>
How close to a t25 is the TD04?
Old Apr 19, 2006 | 09:16 AM
nota-eg's Avatar
Default Re: (1990hondaHF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990hondaHF &raquo;</TD></TR><TR><TD CLASS="quote">How close to a t25 is the TD04?</TD></TR></TABLE>
I'm not really sure. It's bigger than a WRX turbo by a bit.
I'd say you can probably cover the compressor housing with your hand.
Old Apr 19, 2006 | 09:28 AM
DannyDeuce's Avatar
Nissan RB20 turbocharger.........thats what I have on my car.
Spools really quick and has good top end.
DAN
Old Apr 19, 2006 | 10:02 AM
NJcoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports &raquo;</TD></TR><TR><TD CLASS="quote">for 200ish whp, a t3 42/48 will suit your needs. it'll pull to redline and spool up fast
most junkyard turbos (factory dsms and such) will achieve 200hp on a d16...</TD></TR></TABLE>
Old Apr 19, 2006 | 11:46 AM
96ex's Avatar
T3 .60/.48, GT28r or 28RS
Old Apr 19, 2006 | 12:14 PM
rice a roni's Avatar
im going for the 14b...a lot of people make home made kits with it. same td04h turbo from mitsubishi's. thinking of what...250hp after i rebuild my motor? maybe running one bar will make 250hp on a d16z6.
Old Apr 19, 2006 | 12:30 PM
EK k kay's Avatar
Default Re: D16z6...what turbo? (rice a roni)
I'm going with a T3 .60 trim with .48 A/R turbine (.60/.48) on my y7/y8 mini me setup. They spool fairly quickly and will make power throughout the sohc redline.
sharik
Dec 23, 2007 08:15 PM
yaaj1320
Dec 25, 2006 02:53 PM
dumas07
Jul 17, 2006 05:18 PM
GEN2 LS
Sep 28, 2004 12:16 PM
riceburnah
Jul 14, 2004 08:02 PM
