What's this fitting???
Old Apr 18, 2006 | 04:59 PM
B18C_EJ8's Avatar
Default What's this fitting???
This hose fitting is on the throttle body of my B18C, directly below the assembly that the throttle cable attaches to. It's just kindof hanging out down there, not connected to anything, and while I'm no professional, I think it probably should have a hose on it.... I put my finger on it while the car is running, and it's not a vacuum and it there's nothing coming out, so I'm confused... It's gotta be there for a reason!
Old Apr 18, 2006 | 05:04 PM
BlueCrxNC's Avatar
Fast Idle Thermal Valve... Coolant lines run through it. You should hook it back up since you're up north in the cold. When the coolant is cold it allows more air to flow into intake (higher idle)... warm the valve shuts and cuts off the excess air (lower idle)
Old Apr 18, 2006 | 05:08 PM
B18C_EJ8's Avatar
Thanks for the info!!
Would that just tee off from a heater line somewhere or is there a dedicated spot on the block where it gets hooked up?
Old Apr 19, 2006 | 04:57 PM
BlueCrxNC's Avatar
There are hoses that come off of the intake manifold/thermostat/block that lead to various things like your heater core and such. Stock the FITV shares a heater line with the IACV/EACV (located on rear of intake manifold; cuts on with A/C to raise rpms)
Old Apr 19, 2006 | 07:22 PM
JimBlake's Avatar
Default Re: What's this fitting??? (B18C_EJ8)
Sorta hard to tell, but I think it's hose #6 & hose #13.
Old Apr 20, 2006 | 04:14 AM
B18C_EJ8's Avatar
I think you're right about #13...
P. Hunter
Apr 7, 2013 05:46 AM
Lil Gnome
10
Mar 17, 2009 04:49 PM
8_6 luder
Jun 1, 2008 07:23 PM
BseriesHatch
Dec 10, 2003 07:58 AM
IntegraGSR2000
Jan 18, 2002 06:14 AM
