knocking have no idea why
Old Apr 18, 2006 | 04:31 PM
GoneToTheDarkSide's Avatar
Default knocking have no idea why
I just rebuilt the motor in my 91 crx (d16a6 block with z6 head) nothing in the motor is stock... the car was running good up to about 5k rpm because of low compression with no turbo. i tore down to bottom end and replaced the main cap berring (mains and rod berrings where plastiguaged and checked out good) i put the bottom end back together and about a week later it started knocking. I pulled the oil pan and mains and everything still seems to be in spec... the sound is coming from the #1 cillinder but I dont know where exactly... any ideas why it would randomly start this or what it could be?
.... I adjusted the valves and later double checked them about 2 weeks later...
Old Apr 19, 2006 | 08:22 AM
civicstar's Avatar
Default Re: knocking have no idea why (GoneToTheDarkSide)
usually if its nocking like that, its going to be the rods (bearings) but check it to see if any metal shavings are at the bottom of the oil pan
Old Apr 21, 2006 | 02:58 PM
Default Re: knocking have no idea why (civicstar)
the rod berrings are fine and i didnt find anything in the oil pan... im woundering if is is a valve slapping because it only ticks on one stroke (either up or down) its driving me nuts
meuby
May 18, 2010 04:56 PM
streetracerjoey210
Feb 8, 2009 09:31 AM
bdubnyc
Sep 15, 2008 06:30 PM
HatchEh2
Aug 25, 2005 04:35 PM
Kimbo
Apr 25, 2003 09:42 AM
