cant start up !
Old Apr 18, 2006 | 03:44 PM
kingSfit's Avatar
Default cant start up !
i have a 1990 si with a dohc zc , changed the dis. cap and rotor with new spark plugs. but everytime i start it in the cold its fine but when i try to start up when its warmed up it has trouble or doesnt even start at all. and i been getting the code 4 and i think its 17 my speed sensor , not sure though . could it be my dist that needs to be replaced or my alternator? cause both are getting kind of old. and when driving i won't be able to pass 3k ... thanks
Old Apr 19, 2006 | 08:42 AM
kingSfit's Avatar
up
Old Apr 19, 2006 | 09:03 AM
crxnj's Avatar
Default Re: cant start up ! (BUN)
Yeah that 17 is vehicle speed sensor and the code 4 is crank position sensor
Old Apr 19, 2006 | 11:06 AM
JKingCivicSi's Avatar
Does your spedometer work? If your car is in limp mode, its probably code 4 thats doing it. (Correct me if i'm wrong) I think the crank position sensor is inside the dizzy.
Old Apr 19, 2006 | 11:29 AM
nelsmar's Avatar
FAQ: Engine codes:
https://honda-tech.com/zerothread?id=1171263
FAQ: Engine Code Troubleshot:
https://honda-tech.com/zerothread?id=468260
now, i did not post htese to be an *** like most people. these are so you can refrencem y information.
under.... MPFI for code four:
http://www.we-todd-did-racing....3D%3D
follow the first link... read ont he left... follow the second link. this will tell you how to test your distributor for a faulty crank angle sensor.
(code 4 is crank angle). you will need a multimeter to do these test.
I hope this helps you out! and check out the faq on future post for the check engines. so people have a better idea what is wrong.(first link i gave you, bookmark it, comes in handy : P)
Old Apr 19, 2006 | 12:16 PM
kingSfit's Avatar
thanks very useful
Old Apr 22, 2006 | 10:26 AM
nelsmar's Avatar
Default Re: (BUN)
how did it go? get it to start?
Old Apr 22, 2006 | 10:30 AM
cyph3r's Avatar
fix the crank sensor issue and check the main relay.
main relays have a problem with cold solder joints and sometimes wont start when its hot outside
jonney66
Honda CR-V & Element
May 6, 2014 01:24 PM
lsdisk0
16
Aug 14, 2013 04:42 PM
jdmallmotorhatch
Aug 15, 2008 11:03 PM
Creepshow S60
Oct 26, 2003 01:10 PM
