piston / valve clearance y8 b7 mini-me
Old Apr 18, 2006 | 03:09 PM
digitalcongo's Avatar
Default piston / valve clearance y8 b7 mini-me
any known issues
valves & reliefs...etc...
head was milled .003
putting it on a b2 block
the cam has slightly more lift than a y8
y8 = 38.274
3-stage = 38.33
thanx
Modified by digitalcongo at 7:51 PM 4/18/2006
Old Apr 18, 2006 | 05:13 PM
Default Re: piston / valve clearance y8 b7 mini-me (digitalcongo)
bump
Old Apr 18, 2006 | 05:19 PM
schardbody's Avatar
what pistons, and head gasket.
Old Apr 18, 2006 | 07:42 PM
Default Re: (schardbody)
stock b2/b7
y8/z6 gasket
i also have a cometic gasket but i dont know the stats on it...
i assume its the same...dont know
i'd like to use it...
Old Apr 19, 2006 | 07:53 AM
schardbody's Avatar
as long as they are 4 valve pistons it should be fine, dont know many people w/ a cam in a mini me, but i would think it would be ok. you are gonna have some pretty high compression, just the mini me is going to add some then w/ the head milled, so dont forget about that. i would definately clay it first. also, not a bad idea to use some new valve springs if you arent, valve float would kill the motor and it sounds like you are gonna be cutting it close on the "quench" to begin w/.
Old Apr 19, 2006 | 10:49 PM
a cam makes the engine run...
what are your qualifications for your assesment...?
Old Apr 19, 2006 | 11:06 PM
FalkenSiR's Avatar
Default Re: (digitalcongo)
you should be fine.
Old Apr 21, 2006 | 12:08 AM
Default Re: (fast88std)
bump for more backing...
franki16
Jul 12, 2012 07:10 AM
Red_ED8
May 25, 2008 03:54 AM
97grnrs
Dec 10, 2005 11:11 AM
duckmanEG
Mar 22, 2004 07:22 PM
arren123
Jul 13, 2002 05:36 PM
