NON obd motor into a obd1 car.. can i make it work?
Old Apr 18, 2006 | 12:18 PM
4inspeed's Avatar
Default NON obd motor into a obd1 car.. can i make it work?
i have a non obd b16 and was wondering what it would take to run it as and obd1 motor in my 94 hatch? any help would be greatly apreciated.
Old Apr 18, 2006 | 12:45 PM
suckawillis's Avatar
Default Re: NON obd motor into a obd1 car.. can i make it work? (4inspeed)
man you can do it, but its fun work. you need a different ecu, distributor, the manifolds are much diff., new injectors, need to get a new throttle body for map sensor mounting,unless you mount it on the firewall and runn some vaccum lines. oh and a couple mounts are diff. not to mention the cable vs. hydro transmission. I would reccomend selling the first gen and saving up a bit, cause it will be more of a headache and cost more than you think. plus coolant temp sensor is mounted on back of block instead of thermostat housing, so you have plenty of wiring fun ahead of you.
Old Apr 18, 2006 | 01:26 PM
SloB16crxMike's Avatar
Just, find a obd1 distributor, complete obd-1 GSR!!!intake manifold and obd1 ecu, id say get a chipped p28. Bam your done. the GSR intake mani will make a slight increase in acceleration.
Old Apr 18, 2006 | 01:31 PM
4inspeed's Avatar
Default Re: (SloB16crxMike)
gsr intake manifold wont bolt up to a b16 head.
Old Apr 18, 2006 | 01:33 PM
Default Re: (4inspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4inspeed &raquo;</TD></TR><TR><TD CLASS="quote">gsr intake manifold wont bolt up to a b16 head.</TD></TR></TABLE>
correctomundo
Old Apr 18, 2006 | 01:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloB16crxMike &raquo;</TD></TR><TR><TD CLASS="quote">Just, find a obd1 distributor, complete obd-1 GSR!!!intake manifold and obd1 ecu, id say get a chipped p28. Bam your done. the GSR intake mani will make a slight increase in acceleration.</TD></TR></TABLE>
Sorry bud not trying to be rude, but there is a lot more work than that. And that manifold wont work
Old Apr 18, 2006 | 05:17 PM
FaceTuned's Avatar
easy answer use your harness your dizzy cut a leg off or a obd1 b16/b18c a thermo house;n from a obd1 b18/b16 and thats it all others sensor are the same ive done it plenty of times/ use your stock injectors and the throttle body if it has the map sensor on it then your good if not get a vacuum line put it on there and done nothing too hard.
Old Apr 18, 2006 | 06:03 PM
4inspeed's Avatar
Default Re: (jdmhatchness)
thats more or less what i was thinking. i have most of it already, (garage FULL of random parts) just bought another hatch and wanted to through what i had laying around into it, but it was purchased with no engine/tranny in it. so i dont have the stock dizzy or injectors and what not but i will just buy a complete intake mani.
Old Apr 19, 2006 | 11:08 AM
Default Re: (suckawillis)
Oh, Well Damn. I have a GSR intake manifold on my B16a So Iono???
Old Apr 19, 2006 | 11:22 AM
wow, someone must of cut the flange and rewelded, other wise you actually have a gsr head
prelude2121
Engine Management and Tuning
Oct 29, 2010 04:23 PM
MN_F22B1
Sep 24, 2009 06:58 PM
crazyrex
Sep 16, 2005 04:14 AM
bOOsTiNSoHcVtEc
Jun 4, 2005 08:52 AM
90CRXHONDA
May 3, 2004 10:49 AM
