valve stem seals
Old Apr 7, 2002 | 12:29 PM
MIDNIGHT's Avatar
Default valve stem seals
ok got the junk motor running but it rained to day so no autox. but here
is the deal it has a 95 leakdown and it smokes like hell under load. the
head came off of a blown motor that didnt get a oil change for more than a
couple of miles and broke a rod. i am thinking that the valve stems seals are
leaking or cracked.
my ? is can they be changed without head removal or do i need to take it
(the head) off?
thanks
Old Apr 7, 2002 | 05:56 PM
STK B16's Avatar
Default Re: valve stem seals (MIDNIGHT)
its the piston rings, usually you can tell its valves seals on the exhaust side during deceleration. l
Old Apr 7, 2002 | 06:33 PM
rainforest's Avatar
Default Re: valve stem seals (Json79)
well when you did the leakdown did you listen to the exhaust/intake/dip stick HOLE/ to listen for a leak? that can tell you if you where you are having your problem.
Old Apr 7, 2002 | 06:45 PM
Erik_Pb_Foot's Avatar
New User
Default Re: valve stem seals (rainforest)
i'm pretty sure you need to pull the head.... at least on a VR-4 you do, so i'm assuming it's the same on a Honda.
diatibe24
May 9, 2015 08:49 AM
mf1990
Jun 17, 2009 09:11 PM
hazrd420
Aug 13, 2007 08:29 PM
Pandahatch
Jan 8, 2007 06:15 PM
SYN4DRDX
Jul 9, 2005 12:09 PM
