possible problem need advice
Old May 9, 2015 | 08:33 AM
diatibe24's Avatar
Default possible problem need advice
Was working on my car this weekend and noticed something, there appears to be saturation in exhaust port #3. What typically is this indicative of? Is it something to even worry about?
Old May 9, 2015 | 08:41 AM
diatibe24's Avatar
Default Re: possible problem need advice
Oh the head was hot tanked and straight checked recently as I only have like 2 miles on the head since then.
Old May 9, 2015 | 08:42 AM
TheShodan's Avatar
Moderator
Valve stem seal, valve guide, oil sealing ring on the piston. I'm surprised you didn't see this in your exhaust system in the rear view mirror.
Yes, its something worry about. Time to perform some tests. Leakdown, compression, check the head for oil deposits, etc.
Old May 9, 2015 | 08:49 AM
diatibe24's Avatar
Oil seals on my turbo blew and there was oil in everything. There was liquid oil clear back to the muffler. I replaced the oil seals on turbo and ran it again and turbo is good. Threw out the old exhaust because it was just nasty. I went back to just NA and it seemed fine but a tiny bit of smoke came out but only under hard excelleration
Maddvtec
Dec 17, 2010 08:53 AM
Fred931931
Aug 8, 2008 07:33 PM
kornerk12
Jul 20, 2008 07:49 PM
ATgrills.com
Apr 4, 2005 04:29 AM
MIDNIGHT
Apr 7, 2002 06:45 PM
