Check engine light code P0135
My check engine light came on and gave me this code P0135 bank one. Which I believe is the 02 sensor in the exhaust manifold. I recently replaced the 02 sensor and I cleared the code but came on again. This all started when I installed a hi flow cat. Is there anything I can do to remove the check engine light?
The Code P0135 is: o2 Sensor Heater Circuit Malfunction check the depth of the inner portion of the hi flo cat.. i had a problem with in the inner depth was bending and damaging the prong maybe that might help
rickytz7111
Feb 18, 2007 07:04 AM
