Where to buy replication sidemarkers?
Old Apr 18, 2006 | 08:17 AM
O16581724 5 2 5's Avatar
Default Where to buy replication sidemarkers?
I know APC replicates the EP sidemarkers and they're very easy to install, drill a hole for the wires and just screw the into the fender rather than cutting out a shape the size of the inside edge of the marker. We did this on a friends car and it took us quite a few hours and the results weren't so good. Anyway, i've looked around eBay and didn't find anything like what i want, is there such thing?
Old Apr 18, 2006 | 09:15 AM
ef93si's Avatar
just get OEM/JDM side markers, those APC or other sidemarkers that you have to screw in have a bad tendancy to break or have the lense fall off etc. as you need to pop the actual lense off to change the bulb, instead of just popping out the whole unit.
Old Apr 18, 2006 | 09:17 AM
DUFFM4N's Avatar
Default Re: (ef93si)
dude...u cant shell out $40 for some brand new OEM sidemarkers? either way ur gonna end up with some holes in ur fenders...quit being a cheapskate
Old Apr 18, 2006 | 09:19 AM
Thanks knightsport!'s Avatar
I'm a Jackass
Default Re: (DUFFM4N)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DUFFM4N &raquo;</TD></TR><TR><TD CLASS="quote">dude...u cant shell out $40 for some brand new OEM sidemarkers? either way ur gonna end up with some holes in ur fenders...quit being a cheapskate </TD></TR></TABLE>
Old Apr 18, 2006 | 10:38 AM
Default Re: Where to buy replication sidemarkers? (O16581724 5 2 5)
Did you not read the reason i want replication? I don't care if they were $40 as well, i don't want to have to precision cut my fenders to fit them, i just want them screwed in from the back and have a hole in the center for wires.
Anyway, i'm looking at these.
Not too bad, screw in from the front, i'll paint the screws orange. I like the CRX style ones that APC has, too bad they're all clear.
Anyway, they're the most decent looking ones i can find, and they're cheap, got a problem with it?
Old Apr 18, 2006 | 11:03 AM
kaiba's Avatar
Get some reflector and double side tape it.
Old Apr 18, 2006 | 11:18 AM
verycleanhatch's Avatar
I say get some used stanley oem's sidemakers on ebay. I saw a write up on here somewhere and all they did was drill a starting hole and used some type of cutter and it came out clean.
Old Apr 18, 2006 | 11:27 AM
Default Re: Where to buy replication sidemarkers? (verycleanhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verycleanhatch &raquo;</TD></TR><TR><TD CLASS="quote">I say get some used stanley oem's sidemakers on ebay. I saw a write up on here somewhere and all they did was drill a starting hole and used some type of cutter and it came out clean. </TD></TR></TABLE>
I know what's involved, i fucked up a friend's car putting them on, i don't want to expletive up mine. I slipped with the cutter and ground off his paint, then cut part of it a little too much and could see the hole in his fender with the marker installed. I don't mind shelling out the money for the real deal on eBay, they're under $20 shipped, it's just that they're a bitch to install and easy to screw up.
89CRXProject
Jun 5, 2008 06:42 AM
Jbunn2001
Sep 22, 2006 12:51 AM
b18c-1
Jul 31, 2005 07:14 PM
BranzLS
Nov 11, 2003 11:35 AM
b16_madman
Jun 15, 2003 08:56 AM
