New project and ? about surface rust removal
Old Apr 18, 2006 | 05:48 AM
rkeith's Avatar
Default New project and ? about surface rust removal
Here's my newest project I'm working on. I've been looking for one intact and in good shape for awhile and my grandfather snagged this one for me.
I'm planning on restoring it and my question is, what would be the easiest way to remove the surface rust? You can see the front fender that I sanded using a palm sander but even that was a pain. Should I sandblast everything? Recommendations would be appreciated. Thanks--
Old Apr 18, 2006 | 05:52 AM
Timmah!!'s Avatar
Sand blast it man.
Old Apr 18, 2006 | 09:38 AM
JoJO...'s Avatar
hell yea, blast it...
good project..
Old Apr 18, 2006 | 10:29 AM
FrankencrxBHAM's Avatar
Default Re: (JoJo1190)
if you sandblast it youll pit that old metal so fast. best way imo, heavy duty paintstripper and an orbital sander and alot of free time.
Old Apr 18, 2006 | 10:33 AM
ccivic's Avatar
Default Re: (FrankencrxBHAM)
i would get it media blasted.
Old Apr 18, 2006 | 01:16 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: (ccivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">i would get it media blasted.</TD></TR></TABLE>
DING DING DING We have a winner here, media blasting, or glass beading will clean away years of abuse and neglect, without harming the base surface. Good call here.
Clayton
Old Apr 18, 2006 | 09:47 PM
seek167's Avatar
Default Re: (Clayton)
you could acid dip it
Old Apr 19, 2006 | 10:56 AM
Importordomestic's Avatar
Default Re: (seek167)
Media balsting
Old Apr 19, 2006 | 11:40 PM
khoalie's Avatar
Default Re: (Importordomestic)
walnut shizzels?
Old Apr 21, 2006 | 03:20 AM
drewbie's Avatar
Default Re: (Cobra Tim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cobra Tim &raquo;</TD></TR><TR><TD CLASS="quote">Sand blast it man. </TD></TR></TABLE>
use the walnuts
Old Apr 21, 2006 | 03:37 AM
snoochtodanooch's Avatar
you could just have the whole thing media polished, where they put it in a big old tank and run the beads of glass or ceramic of whatever all over the metal. that would probably get you a better surface texture than any of the other methods.
if that isn't available, media blast
Old Apr 22, 2006 | 05:31 AM
kranked91dx's Avatar
Default Re: New project and ? about surface rust removal (rkeith)
you can sand blast it... but it if metal have been thinned by the rust... chance are that you going to past trough...
try with Soda or Nut blast it... nut shel blasting media is a very great de-rustler...
hope this help
kranked
Old Apr 22, 2006 | 05:52 AM
rkeith's Avatar
Default Re: New project and ? about surface rust removal (kranked91dx)
The metal itself is still very strong and intact without any 'soft' spots. Its just surface rust from sitting for the past couple of decades.
Old Apr 23, 2006 | 10:07 PM
sleepingEg8's Avatar
wire brush attachment for a grinder...works good!
Old Apr 23, 2006 | 10:46 PM
L-CON1's Avatar
Default Re: New project and ? about surface rust removal (sleepingEg8)
save some money, go to your local paint supply or hardware store and get some jasco prep and prime and red scotch brite. will do the job just fine and save you some cash. if you soak it with a paint brush and this stuff it will almost all be gone the next day without even touching it.
Old Apr 24, 2006 | 09:54 AM
rkeith's Avatar
Default Re: New project and ? about surface rust removal (L-CON1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L-CON1 &raquo;</TD></TR><TR><TD CLASS="quote">save some money, go to your local paint supply or hardware store and get some jasco prep and prime and red scotch brite. will do the job just fine and save you some cash. if you soak it with a paint brush and this stuff it will almost all be gone the next day without even touching it.</TD></TR></TABLE>
So just brush the prep/prime over the frame? Or use it with the scotch brite and scrub it off?
MidShipCivic
Paint and Body
Mar 13, 2008 11:23 AM
mcgee*
Apr 18, 2006 12:41 PM
Boosted Chemist
Welding / Fabrication
14
Oct 10, 2005 12:41 PM
dclub01
May 12, 2003 11:11 PM
Behan
May 7, 2003 07:02 PM
