What is the best way to remove a window?
Old Mar 12, 2008 | 10:50 PM
MidShipCivic's Avatar
Default What is the best way to remove a window?
Yes I want to do it <u>myself</u>. What the best way?
Old Mar 12, 2008 | 11:18 PM
kelviiv's Avatar
holy
bat much?
Old Mar 12, 2008 | 11:26 PM
Default Re: (kelviiv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kelviiv &raquo;</TD></TR><TR><TD CLASS="quote">holy
bat much?</TD></TR></TABLE>
$150 dollar DA9 shell .
Old Mar 12, 2008 | 11:52 PM
dejavu157's Avatar
tape it from the inside so it doesnt shatter, then try kick it out i guess =P
Old Mar 12, 2008 | 11:53 PM
Default Re: (dejavu157)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dejavu157 &raquo;</TD></TR><TR><TD CLASS="quote">tape it from the inside so it doesnt shatter, then try kick it out i guess =P</TD></TR></TABLE>
Alright I'm looking for some SERIOUS smart techniques here please and thanks.
Come on man I'm for cereal
Old Mar 13, 2008 | 08:48 AM
chairwitharmrests's Avatar
1) take off the weather stripping
2) get a piece of wire like the kind used on brakes on bicycles
3) try to create a whole to get the wire through
4) wrap each end of the wire around each hand
5)saw along the windshield with the wire to cut the glue
6) remove windshiled
Old Mar 13, 2008 | 10:36 AM
samba_green_sol's Avatar
just did this to me ej1 last night let me find the tool i used
you wedge the blade under the glass through the glue and pull on the cable its a bit of work and mine cracked in a few places but it came out in one piece
snap on
http://buy1.snapon.com/catalog...talog its 33 dollars from snap on,
matco
http://matcotools.com/Catalog/...59111 19.95 from matco
Old Mar 13, 2008 | 11:23 AM
welfarepc's Avatar
at the junk yard we would use wire, a bit thinner than the stuff on bicycles... get two little pipes with a hole through the center of each, feed the wire through one of the pipes, wrap it around.. then feed the other end through a slit in the urethane you are going to cut with a olfa blade. once the wire is through feed it through your other pipe, wrap it tight and start sawing
ecahatch
Jul 14, 2007 11:56 AM
RACEPAK
11
Mar 23, 2007 01:50 PM
RS Design
Jul 10, 2006 06:00 AM
roundworldsobig
Sep 28, 2005 09:54 AM
Team-S
Honda S2000
Dec 13, 2003 07:59 PM
