coolant leaking!!! someone help!!!!!!!!
Old Apr 17, 2006 | 09:30 PM
90efSI's Avatar
Default coolant leaking!!! someone help!!!!!!!!
well i was installing my oil feed line into the back of the block and when i fed the line from the bottom of the car to the top all of the sudden i feel.....drip....drip on my head so im like wtf, ...it stopped for awhile then when i was moving the radiator around all of the sudden it starts dripping agine but alot faster...my radiator will be completly draind probably in about 10 min...so can someone tell me wtf happened?!?!? heres a pis of where it is leaking from...i have no idea what this is?!?!? some one please HELP!!!!!!!!!
Old Apr 17, 2006 | 10:25 PM
jdmcrx90's Avatar
Default Re: coolant leaking!!! someone help!!!!!!!! (90efSI)
is that on the back of your block?
Old Apr 18, 2006 | 03:07 AM
STREETWERKZ's Avatar
Default Re: coolant leaking!!! someone help!!!!!!!! (jdmcrx90)
looks like a drip to me.
can you get a better picture? i cant tell where thats is coming from.
Old Apr 18, 2006 | 04:02 AM
Cory man's Avatar
Default Re: coolant leaking!!! someone help!!!!!!!! (STREETWERKZ)
That is the water pipe from the water pump to the t stat housing. There is a small o-ring that fits over the top of the pipe itself. You will have to remove the t stat housing in order to remove the water pipe and o ring seal. Use a small amount of lubricant on the seal when you insert the water pipe into its housing to prevent the new oring from getting torn etc. Pretty easy fix. hth
Old Apr 18, 2006 | 07:14 AM
EJ1 wilcox's Avatar
Default Re: coolant leaking!!! someone help!!!!!!!! (Cory man)
Yeah, you are going to need to replace that o-ring.
It's a cheap fix, but a total pain in the *** because you have to remove all the hoses to get the water tube out of there.
Old Apr 18, 2006 | 02:09 PM
90efSI's Avatar
Default Re: coolant leaking!!! someone help!!!!!!!! (EJ1 wilcox)
yea i think its more then the o-ring tho b\c there are multiple leaks...heres more pics
Old Apr 18, 2006 | 02:26 PM
fourthgenhatchB17's Avatar
iwould put in new water pipe O rings (theres one on each side) and all new coolant hoses. Its also possible that the water pipe has corroded enough to not allow the o ring to seal properly, but you wont know that until u take it apart.
Old Apr 18, 2006 | 04:17 PM
90efSI's Avatar
k how do you get the water pipe out?!?!?
Old Apr 18, 2006 | 04:56 PM
90efSI's Avatar
BUMP
Old Apr 18, 2006 | 05:14 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (90efSI)
I would make sure that is where it is leaking
by pressure testing it as there are several places
it could leak from...
There is a pic of the pipe here:
https://www.hondapartsdeals.co...7.gif
Old Apr 18, 2006 | 07:45 PM
90efSI's Avatar
yea i donno how to pressure test so can someone just tell me how to remove this water pump pipe or coolant pipe or w/e it is?!?!?
Old Apr 18, 2006 | 07:54 PM
Just go buy yourself a cheapy manual.
Old Apr 18, 2006 | 08:41 PM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90efSI &raquo;</TD></TR><TR><TD CLASS="quote">yea i donno how to pressure test </TD></TR></TABLE>
Get a cheap radiator pressure tester taht clamps on to the radiator cap inlet. Then just pump until you force a leak ( I don't know why that was funny to me)
highwhey
Dec 27, 2013 05:09 AM
serg92hatch
20
Jan 31, 2010 09:08 PM
krysted9354
Jan 27, 2009 03:34 PM
black-lude
Jul 19, 2007 12:31 AM
my97accord
Jan 31, 2005 05:20 AM
