Urgent help needed please. No Brakes!
Hi
I have searched and couldnt find an answer. I can't get any brake pressure after i did a rear disc conversion. when trying to bleed no fluid comes out but i can feel resistance from the master cylinder. When trying to bleed them the reservoir doesn't go down either.
Please help
Please help
i dont think i did as they were hard lines and surely id still hav a fair bit of pressure if only one line was pinched? i hav a non abs setup and the rear discs were off a car with abs, would that matter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NZDelsoldude »</TD></TR><TR><TD CLASS="quote">i dont think i did as they were hard lines and surely id still hav a fair bit of pressure if only one line was pinched? i hav a non abs setup and the rear discs were off a car with abs, would that matter?</TD></TR></TABLE>
no...
no...
The reservior goes down when the pedal is pushed but comes back up to the same level. (like its not going through the system). But i'm getting fluid pumping from my mc and out of the prop valve.
Touch
Oct 29, 2006 09:32 AM
