Suspension & Brakes Theory, alignment, spring rates....
suspension noise, need a conclusion.
Old Apr 17, 2006 | 06:33 PM
De_tour's Avatar
Default suspension noise, need a conclusion.
Modified by De_tour at 8:17 PM 4/17/2007
Old Apr 17, 2006 | 10:06 PM
De_tour's Avatar
Default Re: suspension noise, need a conclusion. (wspcivic)
bump
Old Apr 18, 2006 | 08:05 AM
crashedacar's Avatar
i have the tein ss on a 98 ek. i was hearing some scraping sounds in the canyons when i was taking a turn at high speed or correcting a little bit of understeer. it turns out i was scraping the mud flaps from the dealer around turns. dont know if that could be it. what is ur camber like? id also pull off the wheel. check wheel well for any rub marks. along with ur tires for rub marks. but thats just me. hope i helped. good luck.
Old Apr 18, 2006 | 09:05 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: suspension noise, need a conclusion. (crashedacar)
First thing you should check is your trailing arm bushings. Look into your fender well at the bottom front. You will plainly see the trailing arm, and it's huge round bushing where it mounts to the chassis (you don't even have to lift the car). Usually it wears out really fast on a lowered car because it's always twisted, so make sure it's okay. When the rubber cracks, it rubs against itself when your turning, and it will make lots of noise...
Old Apr 18, 2006 | 11:17 AM
De_tour's Avatar
Default Re: suspension noise, need a conclusion. (94eg!)
Old Jun 20, 2006 | 02:07 PM
De_tour's Avatar
Modified by De_tour at 8:18 PM 4/17/2007
Old Jun 21, 2006 | 08:38 PM
FalkenSiR's Avatar
Yup, that's what mine looks like It seems to make a rubbing sound when I go up driveways. Basically whenever the wheel travels up and down a lot. Not very noticeable but kind of annoying at times.
Old Jun 24, 2006 | 12:51 AM
ak47autolock's Avatar
Default Re: suspension noise, need a conclusion. (fast95eg8)
I get a kind of a rubbing/clunking noise at slow speeds going over bumps. I was told it was my trailing arm bushing, but if I reach up from under my car and grab the spring it's seems to be coming from the top of the spring. (not sure what suspension it has, bought it mod'd)
Old Jun 25, 2006 | 10:00 AM
De_tour's Avatar
Default Re: suspension noise, need a conclusion. (ak47autolock)
rubber washer for the spring?
Old Jun 25, 2006 | 10:58 AM
Dwight Schrute's Avatar
you should probably replace your trailing arm bushings. they dont look so hot. i think i told you this in another post because i've seen that pic before.
Old Jun 25, 2006 | 12:54 PM
SiRay13's Avatar
could be your sway bar, sometimes the poly bushings will squeak around hard turns.
coco718
Honda Civic (2001 - 2005)
12
Oct 28, 2011 09:27 PM
elnoyl
11
Feb 19, 2011 05:45 PM
Woody.
Suspension & Brakes
Jan 6, 2011 10:48 AM
CSSMiketsi
Suspension & Brakes
Jun 6, 2007 11:03 AM
dgonzals
Apr 17, 2004 11:58 AM
