normal water tem for a sohc?
Old Apr 17, 2006 | 06:33 PM
lito1208's Avatar
Default normal water temp for a sohc?
hey guys just want to know what is the normal water temp for a sohc? I had the head ported and intake, zex aggresive cam, 20 over piston,headers. I have change the thermostat to 180". but it p still running to 210' can anyone help me please?
Old Apr 18, 2006 | 07:37 AM
YasRex's Avatar
Default Re: normal water temp for a sohc? (lito1208)
That's not normal. Do the regular coolant system checks.
Old Apr 19, 2006 | 01:17 AM
lito1208's Avatar
okay I got it down to 200' is that okay? I had to change the thermostat to 170 but it still go up to 200" during normal driving.
Old Apr 19, 2006 | 05:56 AM
YasRex's Avatar
Default Re: (lito1208)
When you change the thermostat to 180 degrees or whatever it changes the temp your coolant system starts circulating sooner. There is no reason to change this to a lower temp unit because your car is optimized for a 180 degree unit.
The problem is that once your thermostate opens up, allowing coolant in the engine, it is unable to cope with the heat generated. You need to find the obstruction in your cooling system preventing you from keeping your temp down. Check your coolant level, run it w/o the cap on to remove bubbles, etc.
Old Apr 19, 2006 | 01:43 PM
PURPLETERROR aka BIGMATT's Avatar
go to the honda dealer and buy an oem thermostat for your car. ever aftermarket thermo I have ever used runs way to hot.
Old Apr 19, 2006 | 03:16 PM
quicksilver1689's Avatar
i ♥ snails
The oem ones are quality and usually dead on calibrates some of the aftermarket **** has a crappy tolerance and can be off by a number of degrees.
vinceiscoo
12
Sep 5, 2008 11:02 AM
cr-rex88
Feb 17, 2006 07:58 AM
pentaq
Sep 13, 2005 03:19 PM
benmasters
May 25, 2003 12:47 PM
pelotudo
May 13, 2002 11:16 AM
