do i need a new starter for auto to manual swap?
Old Apr 17, 2006 | 02:12 PM
omgwtfbbqcrx's Avatar
Default do i need a new starter for auto to manual swap?
Old Apr 17, 2006 | 02:19 PM
Default Re: do i need a new starter for auto to manual swap? (omgwtfbbqcrx)
bump1
Old Apr 17, 2006 | 04:24 PM
psyloki's Avatar
no u can use the auto starter, axels, ecu
i did the swap about a year ago
the pedals are the hardest part
Old Apr 17, 2006 | 05:13 PM
i already put everything in except the linkage, starter, clutch cable, and axels
Old May 24, 2006 | 12:18 AM
joker4096's Avatar
Default Re: (omgwtfbbqcrx)
i think if it is an ek, you need a manual starter, dont know about the egs
Old May 24, 2006 | 01:14 AM
bks84's Avatar
Loved
Default Re: (joker4096)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joker4096 &raquo;</TD></TR><TR><TD CLASS="quote">i think if it is an ek, you need a manual starter, dont know about the egs</TD></TR></TABLE>
Well this isnt the EK/EG forum, its the EF.
You can use the auto axles, but I dont recommend using the Auto ECU. Spring for the manual, better fuel maps and not as low rev limiter, from what im told.
Old May 24, 2006 | 04:13 AM
SVOboy's Avatar
This makes me go yay, starting (and hopefully finishing) the swap friday after work.
Old May 25, 2006 | 08:38 PM
joker4096's Avatar
Default Re: (4sd4dr)
i figured that you can use the auto starter but i had to redrill the holes for it to fit and get a longer bolt for it to hold onto the engine. i dont have that bolt, but mine's holds fine with one.
xkrazyxjbrkerx75
Apr 29, 2009 01:23 PM
dschenke
Mar 29, 2009 01:16 AM
stackz
Jan 7, 2007 05:02 PM
mr poo
Jul 29, 2006 02:59 PM
hybridpatient95
Apr 22, 2005 12:38 AM
