98 civic auto-manual swap question:: NEED TO SWAP STARTERS?
i just did an auto-manual swap, the guy said you dont need to swap the starters cuz they're practically the same.
now my car wont start.
i just tested the battery it is PERFECT.
the car just turns on, clicks once and nothing happens
are auto and manual starters different on 96-00 civics?
Re: 98 civic auto-manual swap question:: NEED TO SWAP STARTERS? (mr poo)
does your car have a starter solenoid?? had a car that did that and turned out to be a shot starter solenoid
as far as i know, for a 92-25 civic a manual starter and auto starters are different. I did a swap too and had to get a manual starter as an auto one didn't work. I'm pretty sure this applies the same for 96-00 models but i'm not positive.
Re: (byronl)
I just did a auto to manual conversion on my 94 Civic. The automatic trans starter is physically different and both bolts will not fit on the manual transmission. Electrically they both function the same.
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Can it possibly be the main relay?
Do you have a manual starter in there?</TD></TR></TABLE>
whats the diff. between a manual and automatic starter?
i was told there were none
Re: (mr poo)
Auto and manual are different. You could see it right away just looking at it. You need a manual. If you drove your car with the auto one then more then likely you dont have the auto one unless if its ghetto rigged up. Try taking it out (if you know how) and get it tested at autozone.
xkrazyxjbrkerx75
04-29-2009 01:23 PM
HondaIsBueno
10
04-14-2008 08:14 PM
stackz
01-07-2007 05:02 PM
omgwtfbbqcrx
05-25-2006 08:38 PM
