TW FS / FT 88 crx b16a obd1 y1 w/lsd full peakboost kit
well i decided to get out of the army and go to school so i think its time to sell. its got around 4000 miles since the swap. everything was done by Tuners Edge. Tuning was done by Custom Car Care. setup made 276hp @ 7psi on a dynapack.
not sure what the going rate is for a car with this setup so im taking offers. i have most of the reciepts for everything and the dyno sheet. here is everything i can remember off the top of my head. vin avail. for serious buyers. located in VA
would consider trades also. full interior is now back in. ill post money shots when it quits raining
jdm b16 swap
Y1 tranny w/lsd
full peakboost kit
HPC coating on the manifold
TIAL wastegate
TIAL BOV
powdercoated intercooler piping
hcp mounts
full OBD 1 conversion
new distributor, 4 wire o2 sensor, p28 ecu
hondata s200b with all options (datalogging, rev limit, launch control, full throttle shift, shift light)
full-race radiator
full-race traction bars
ngk wires, o2 sensor and plugs (BKRE7-11)
walboro 255lph fuel pump
RC 550 cc injectors
new fuel tank and sending unit
integra rear disc conversion
40/40 proportioning valve
new master cylinder
findanza 7lb flywheel
XTD 6 puck srung clutch
JKOBD conversion harness
joe p manual boost controller
relocated battery
3" turbo back kteller exhaust
3" magnaflow muffler
B&M short shifter
poly lca bushings and shifter bushings
neuspeed swaybar
B&G full coilovers
new oil pump, water pump, timing belt, cam seals
UKDM cluster
stainless steel braided brake lines
Dino leather steering wheel and hub
Del Sol seats
12" slim fan
new oem window weatherstripping (not installed) for front window and 1/4 windows
jdm b16 swap
Y1 tranny w/lsd
full peakboost kit
TIAL wastegate
TIAL BOV
hcp mounts
full-race radiator
RC 550 cc injectors
new master cylinder
relocated battery
B&M short shifter
neuspeed swaybar
B&G full coilovers
UKDM cluster
Del Sol seats
12" slim fan
isquishplatano
May 26, 2008 07:38 PM
AllMotorB16RoadRacer
Apr 8, 2008 11:49 AM
Pee Wee
Apr 26, 2006 07:06 AM
