Suspension & Brakes Theory, alignment, spring rates....
Bent front knuckle= mad camber???
Old Apr 17, 2006 | 06:59 AM
sportyaccordy's Avatar
Default Bent front knuckle= mad camber???
Can a knuckle bend, and if it does, could it be the cause for wild negative camber? I was messing w/my sleeves yesterday and I noticed on the right side the knuckle was basically touching the spring perch. I've had crazy camber on that side ever since I went through a pothole that took out both tires on the right side of my car...
So yea, is it possible? And would it be wise to get a knuckle with a rotor on it? Thx.
Old Apr 17, 2006 | 08:03 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Bent front knuckle= mad camber??? (sportyaccordy)
Yes it is possible. You may need professional help to determine the extent of the damage. Other parts could be messed up & can't really tell. You should probably take it to a collision repair place so they can let you know whats up & what to fix first...
Old Apr 17, 2006 | 08:39 AM
mrchaos's Avatar
I had the same problem, bent knuckle causing bad camber in the front. Bought it as part of a brake swap, just got another from the wreckers - problem solved.
Old Apr 17, 2006 | 08:58 AM
Tyson's Avatar
they bend quite easily actually...
Old Apr 17, 2006 | 09:52 AM
Default Re: Bent front knuckle= mad camber??? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">they bend quite easily actually...</TD></TR></TABLE>
Bah...good to know. I'm scared I might have some frame damage; but just by running back and forward comparing both sides it looks like the knuckle is the culprit. I'll try and get a new one this week...
Old Apr 17, 2006 | 10:39 AM
hayabusa160's Avatar
they can snap pretty easy too.
Old Apr 17, 2006 | 10:53 AM
Default Re: Bent front knuckle= mad camber??? (hayabusa160)
hayabusa dude: THAT'S BONKERS!!! PLEASE TELL US THE STORY!!!!!
Old Apr 17, 2006 | 11:13 AM
some old bitch hit me pretty hard on my passenger side in a parking lot.
speed limit in a parking lot is 15.
she was speeding but the cops didnt care.
it was a good thing it snaped tho it took all the energy.
so not much stuff got damaged there.
Old Apr 17, 2006 | 01:01 PM
Yea, if not for our suspension design it could have been much worse...
gt3civic
May 14, 2007 07:27 PM
Immanuel
Feb 16, 2007 06:45 PM
jdmstreethatch
Suspension & Brakes
Feb 4, 2006 11:52 AM
TSL
May 26, 2005 06:35 PM
smikeL
Jan 7, 2005 11:13 PM
