burning oil
Old Apr 16, 2006 | 08:42 PM
B18C-YA!'s Avatar
Default burning oil
is it normal for the B16 to burn oil when hitting vtec? thanks
Old Apr 16, 2006 | 08:53 PM
Syndacate's Avatar
Ummm...I don't think it's ever normal for any car to BURN oil...
EDIT:
Oh yeah, in response, I've never had that engine, but I'd assume it's VERY NOT normal for it to burn oil when hiting vtec
Old Apr 16, 2006 | 09:56 PM
spankey167's Avatar
Default Re: (Syndacate)
B series vtec engines tend to burn oil. Some more than others... It depends who much you burn...
Old Apr 16, 2006 | 10:07 PM
KoLRaNcH's Avatar
Default Re: (spankey167)
Mine eats oil like crazy.
Old Apr 16, 2006 | 11:04 PM
Rayz_Si's Avatar
From: Land of the Hillbillies and Shotguns, Ontario, Canada
Default Re: (KoLRaNcH)
That is totally normal for your engine to eat oil in VTEC mode don't worry. In hondas, the PCV venting system cannot handle large amounts of pressure during high RPM VTEC mode, so it forces the oil into the combustion chamber and burns it. EVERY VEHICLE even BRAND NEW will burn oil, just a smaller amount this is normal in the internal combustion engines, it's just when you are in higher RPM's and VTEC in Hondas you burn alot more oil than usual.
The only solution I have seen was to use an external PCV canister by Moroso.
Another solution to reduce burning your oil, PLUS saving your engine, saving your licence, and savng your life would be to just take it easy on your baby and enjoy the drive.
Old Apr 23, 2006 | 06:51 PM
JDM B16A's Avatar
I hit Vtec in my JDM B16A all day everday and my oil is always at its full level. So this oil burn'n is bullshit. Don't give tips you don't know about. BTW my oil hasn't been change for a little over 2 months and its still at full level.
Old Apr 23, 2006 | 06:57 PM
aquabob89's Avatar
* B A N N E D *
Default Re: (JDM B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rayz_Si &raquo;</TD></TR><TR><TD CLASS="quote">That is totally normal for your engine to eat oil in VTEC mode don't worry. In hondas, the PCV venting system cannot handle large amounts of pressure during high RPM VTEC mode, so it forces the oil into the combustion chamber and burns it. EVERY VEHICLE even BRAND NEW will burn oil, just a smaller amount this is normal in the internal combustion engines, it's just when you are in higher RPM's and VTEC in Hondas you burn alot more oil than usual.
Another solution to reduce burning your oil, PLUS saving your engine, saving your licence, and savng your life would be to just take it easy on your baby and enjoy the drive. </TD></TR></TABLE>
Normal to burn oil... maybe.
Old Apr 23, 2006 | 07:05 PM
CardDealer's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16A &raquo;</TD></TR><TR><TD CLASS="quote">I hit Vtec in my JDM B16A all day everday and my oil is always at its full level. So this oil burn'n is bullshit. Don't give tips you don't know about. BTW my oil hasn't been change for a little over 2 months and its still at full level.</TD></TR></TABLE>
From everyone I know on HT and at home with a B16, I think you're in the minority. Hell, even my friends brand spankin new S2000 consumes oil when he gets on it a lot.
Unless you're burning over a quart every 3000 or see blue smoke out the tailpipe, then I wouldnt worry.
Old Apr 23, 2006 | 07:23 PM
JDM B16A's Avatar
yea, I might be that lucky few. But not one ounce of oil is burnt even though I engage Vtec at least 20 times a day for the past 2 1/2 months.
Old Apr 23, 2006 | 07:43 PM
O RLY's Avatar
I have Crower turbo cams in my N/A H22 and I use about a quart every 2000 miles. Usually a moderately modified engine will burn a quart every 3000 miles. Just keep an eye on it, and always carry a quart of Castrol GTX 10w30.
Old Apr 23, 2006 | 07:45 PM
CardDealer's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16A &raquo;</TD></TR><TR><TD CLASS="quote">yea, I might be that lucky few. But not one ounce of oil is burnt even though I engage Vtec at least 20 times a day for the past 2 1/2 months.</TD></TR></TABLE>
So is that why your tranny is grinding?? Beats me man, do you have a stock setup?
Old Apr 23, 2006 | 08:47 PM
Rayz_Si's Avatar
Tips i don't know? . Everyone I know on HT, 2 buddies with brand new s2000, friends and more freinds with VTEC motors all consume oil
If you know more about tips than me, do you know that every internal combustion engine consumes oil even BRAND NEW FROM THE FACTORY?
Modified by Rayz_Si at 5:44 AM 5/3/2006
Old Apr 23, 2006 | 08:51 PM
Rayz_Si's Avatar
Default Re: (Rayz_Si)
Sorry to come of harsh like that dude,
Look the fact is, every motor burns oil but which ones burn more&gt;?
1.The ones that hit higher RPMS alot (spirted driving, VTEC mode)
2. The ones with worn lower oil control piston rings
3. The ones with worn valve seals.
Some engines burn more oil than others.
Old Apr 24, 2006 | 06:25 PM
JDM B16A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit &raquo;</TD></TR><TR><TD CLASS="quote">
So is that why your tranny is grinding?? Beats me man, do you have a stock setup? </TD></TR></TABLE>
Yea, but what B series 3rd gear doesn't grind? B series are known for weird tingling/clicking/knocking sound where around the valve area and 3rd gear grind.
Old Apr 24, 2006 | 07:37 PM
JDM B16A's Avatar
LOL I like how Rayz_Si flamed my *** then try did a cover up. ha!
Old Apr 24, 2006 | 07:45 PM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">Ummm...I don't think it's ever normal for any car to BURN oil...
Every engine burns oil. Period. The difference is how much it burns. Industry standard for a rebuild is 1qt per 1000mi before needing a rebuild.
Hondas tend to burn more than other motors, especially if you have VTEC. The high compression / high revving motors burn more than an average motor.
I have to usually put 1/2 to 1qt between oil changes in my D16 VTEC (about 5 - 6K miles)
Old Apr 24, 2006 | 07:53 PM
JesSi's Avatar
Default Re: (AutoXer)
I usually keep a quart of Mobil 1 Synthetic 5w30 in a rear seat cupholder. From everything i've experienced a little oil burn between oil changes is normal if you're in VTEC alot.
Old Apr 24, 2006 | 07:58 PM
AutoXer's Avatar
Default Re: (JesSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JesSi &raquo;</TD></TR><TR><TD CLASS="quote">I usually keep a quart of Mobil 1 Synthetic 5w30 in a rear seat cupholder. </TD></TR></TABLE>
I've always burned more when using M1; just figured I'd throw that side note in there.
Old Apr 24, 2006 | 08:21 PM
fmrprojects's Avatar
the higher you rev with thinner oil, it will burn. try switching to a thicker oil
Old May 1, 2006 | 06:35 AM
Rayz_Si's Avatar
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">the higher you rev with thinner oil, it will burn. try switching to a thicker oil</TD></TR></TABLE>
True
sorry agaian JDM B16, i don't know what the heck got in to me, I am hardly like that.
Old May 1, 2006 | 08:09 AM
O RLY's Avatar
My H22 was rebuilt about 8000 miles ago. It has Mahle 87.25 mm 9.1:1 forged pistons, Eagle H-beams, Crower valvetrain w/ Crower stage 2 turbo cams, and is fully tuned with a Hondata S200. I still find it burns 1.5-1.75 qts of 10w30 every 3000. So I'm switching to 20w50 Castrol GTX. I ran non detergent oil for the first 800 miles or so, then went synthetic 5w30&gt;regular 5w30&gt;10w30&gt; now 20w50. We'll see what will happen. I may hafta start running maple syrup soon.
Old May 1, 2006 | 07:19 PM
JDM B16A's Avatar
Default Re: (O RLY)
okay, results are back. It appears my JDM B16A is burn'n a little bit of oil. After reading some threads i decided to keep track on my oil. well i guess after engage'n vtec about 20 times a day all day everyday! my oil did go down just a little. not much just a iddy biddy little. about this much went down from the MAX
"__"
Old May 1, 2006 | 07:25 PM
E46Kid's Avatar
yes, its normal
Rayzsi's girlfriend is a fatass seen her on clubsi lol!
Old May 1, 2006 | 08:43 PM
JDM B16A's Avatar
Default Re: (EkSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EkSi &raquo;</TD></TR><TR><TD CLASS="quote">
Rayzsi's girlfriend is a fatass seen her on clubsi lol!</TD></TR></TABLE>
no fat chick for me please. i like my woman slim and slender.
Old May 1, 2006 | 09:25 PM
GetawayInMoscow's Avatar
It's definitely normal to burn oil if you drive your car hard. My B16 didn't smoke but if I went ot the to the track I would burn a quart after like 20 passes or so.
