DC2 turbo vacuum line hook up....
Old Apr 16, 2006 | 03:35 PM
PhantomX's Avatar
Default DC2 turbo vacuum line hook up....
anyone have any information (Pics will really help too) on how to hook up all the vacuum lines together?... i have a golden eagle vaccum manifold ....do i just run a line straight from the bov/wastegate/boost gauge... to the GEmanifold?? that leaves 3 more ports...what are they for?
*also where can i buy vacuum lines? i tried orchard but they didnt have anything*
*did a search...didnt really find anything that helped*
(not my car)
Old Apr 16, 2006 | 03:51 PM
Muckman's Avatar
Moderator in Chief
Default Re: DC2 turbo vacuum line hook up.... (PhantomX)
You dont need a pic, you already have a good enough pic. Just run the vac lines to those 3 sources from the vac mani. And T off the brake booster to feed the vac mani. You can get vac line from pepboys or napa. The other 3 ports on the GE vac mani are extra, they should be sealed just leave them.
Old Apr 16, 2006 | 03:57 PM
PhantomX's Avatar
Default Re: DC2 turbo vacuum line hook up.... (Muckman)
oh kool..... does pepboys or Orchard have anything that can seal the extra ports?
Old Apr 16, 2006 | 03:59 PM
INTEGRA_boy's Avatar
just use a "W" tee from like auto-zone. then hook it up to your fuel pressure regulater then run the vacume lines from that to the waste gate and the BOV
Old Apr 16, 2006 | 05:17 PM
SlwGsr's Avatar
Default Re: DC2 turbo vacuum line hook up.... (INTEGRA_boy)
could you specify some of the details in this method. im kind of curious to
Old Apr 16, 2006 | 05:43 PM
ccivic's Avatar
Default Re: DC2 turbo vacuum line hook up.... (SlwGsr)
Cut your brake booster line (large vacuum line coming off back of intake manifold) BEFORE THE PCV VALVE and put the vacuum manifold in line with it.
brakebooster->ge vac mani->brakebooster.
Leave the unused ports on the vacuum manifold sealed, and voila.
As stated, vacuum line can be purchased at almost any parts store-- Autozone, AdvanceAuto, NAPA, etc.
Old Apr 16, 2006 | 07:59 PM
Soccerking3000's Avatar
Default Re: DC2 turbo vacuum line hook up.... (ccivic)
ya you dont need to seal the unused ports, all the ports come sealsed you drill out the ones you use
Old Apr 16, 2006 | 10:06 PM
PhantomX's Avatar
Default Re: DC2 turbo vacuum line hook up.... (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">ya you dont need to seal the unused ports, all the ports come sealsed you drill out the ones you use </TD></TR></TABLE>
you sure?...because when i look through it.. its open
Old Apr 17, 2006 | 04:12 AM
Chris22215's Avatar
yeah they'll all be sealed if you bought it new. you have to drill out the ones you need and just leave the rest alone
Old Apr 17, 2006 | 10:48 AM
tgreaves's Avatar
Get your vacuum lines from atpturbo.com...
Old Apr 18, 2006 | 12:52 PM
PhantomX's Avatar
Default Re: DC2 turbo vacuum line hook up.... (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Get your vacuum lines from atpturbo.com...</TD></TR></TABLE>
kool what size should i get?? 1/8th?
Oh yea the GE manifold is sealed..... i finnaly opened it and checked it out....
Modified by PhantomX at 2:32 PM 4/18/2006
Old Apr 18, 2006 | 01:03 PM
that should be fine get silicon hosing not rubber its much better
edit: get some 1/4 inch too just to be safe some of the barbed fittings will be too large for 1/8inch
Old Apr 18, 2006 | 01:34 PM
PhantomX's Avatar
ok ... thankx for the info fellaz
Old Apr 18, 2006 | 02:35 PM
LostSolVTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic &raquo;</TD></TR><TR><TD CLASS="quote">Cut your brake booster line (large vacuum line coming off back of intake manifold) BEFORE THE PCV VALVE and put the vacuum manifold in line with it.
just wanted to make that clear
03EM2guy
May 13, 2008 10:07 AM
almostboostedgsr
Mar 14, 2007 08:23 PM
turbotime
Apr 23, 2006 08:25 PM
Justin Olson
Nov 20, 2005 08:05 PM
T25 civic
Oct 30, 2002 06:17 PM
