A/C only blows hot????
Old Apr 16, 2006 | 03:32 PM
senn1n103's Avatar
Default A/C only blows hot????
Can any of you tell me if you've had this problem? My 1993 Del Sol S' A/C just stopped working one day. I was driving and the sun came out so I pushed the climate control all the way to the blue side. Then I turned the dial to 4 which is the highest setting, then pushed the A/C button. The thing only blew hot air. I waited forever, but still only hot. I know the system is charged, so it can't be low refrigerant. It takes R-12 if that matter. Has anyone had this problem. Any info. would be greatly appreciated. Thanks
Old Apr 16, 2006 | 03:35 PM
Lightweight Boost's Avatar
it might be leaking , check all the lines
Old Apr 16, 2006 | 03:39 PM
d16Booger's Avatar
Maybe recharged
Old Apr 16, 2006 | 05:01 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (d16Booger)
It could be a number of things. You have to try and diagnose it by checking most of these.
1. Bad/clogged heater core.
2. Heater core flap thing (the flap that opens and closes it) is stuck.
3. The A/C compressor is malfunctioning/clutch not engaging, etc.
4. The cable/metal temperature slider bar is disconnected and not actually moving anything.
There are probably more, but these are the ones off the top of my head. Also, how do you know the system is charged? It could have been done recently, but that doesn't mean there isn't a leak and it all came right back out.
Old Apr 16, 2006 | 05:20 PM
vtecnologist's Avatar
Default Re: (shamoo)
did you purge it to make sure therres still freon in it,
if there is, check the compressor
Since 1983
Apr 29, 2008 12:23 PM
Pooby88
Jan 12, 2008 08:42 AM
ekferio
Nov 3, 2006 06:12 AM
srv3fender
Jul 23, 2006 09:37 AM
DarkBB4
Dec 14, 2004 10:16 PM
