car jumping around like a crackhead
Old Apr 16, 2006 | 03:15 PM
mugenwannabe's Avatar
Default car jumping around like a crackhead
88 crx z6 block, a6 head, zc pistons
coming home from work yesterday and running a lil low on gas. thought i could make it to the gas station...nope. car falls on its face, no power when i push the throttle. pull over and coast to a stop. try and start it and it sounds like its backfiring and i get a puff of grey smoke out my exhaust. try and crank a couple more times, and the same thing. go to check my timing and no. 1 cyd is at tdc, and in line w/ the cam gear. timings not off. check over everything, all 3 grounds connected, amount of oil good, no fluid leaks, car is not overheating, no fluid on any of the spark plugs. it looks like it should run.
go to crank it again, and she starts. wtf. put her in drive, has no power, and when i give it more than 15% throttle, or go above 1500 rpm, the whole car jumps back and forth very violently. but it does get me to the gas station at 5 mph about a mile away. guess gas wasn't an issue. now what demon has gotten into my car and started tearing things apart?
Modified by mugenwannabe at 4:28 PM 4/16/2006
Old Apr 16, 2006 | 03:48 PM
bump
Old Apr 16, 2006 | 04:14 PM
jpciii's Avatar
a distributer can go bad all of a sudden and cause bizzare problems like that. They are expensive, though. If you can find a known working one to try, I would do that.
Old Apr 16, 2006 | 09:19 PM
E_F_9's Avatar
if you ran it low on gas the fuel filter might have gotten trash in it
Old Apr 16, 2006 | 11:26 PM
shbrown's Avatar
Default Dizzy
Check the ignitor.
Old Apr 17, 2006 | 06:36 PM
will try a diff. dizzy tomm
Old Apr 20, 2006 | 04:32 PM
tried a new dizzy, idles ruff and sputters when the accelerator is pushed
Old Apr 21, 2006 | 10:49 AM
E_F_9's Avatar
change the fuel filter
Old Apr 21, 2006 | 11:15 AM
elchapin's Avatar
I can tell you it def is the coil in the dist. This happened exactly like you said.
Old Apr 22, 2006 | 01:45 PM
Default Re: (mugenwannabe)
tried a new fuel filter, same ****.
Old Apr 22, 2006 | 02:21 PM
throwing a code 16 - fuel injectors. but when i unplug each one while the cars running, the idle changes showing they're not bad. does the code apply to anything else within the fuel system?
Old Apr 22, 2006 | 03:16 PM
ILcrxsi1's Avatar
I tell doctors what to do
It sounds like the fuel pump might be taking a **** on you. A fuel flow test would be nice if you can get the tool.
Old Apr 22, 2006 | 03:59 PM
jdmazm's Avatar
Default Re: (illcrxsi1)
change the main relay, replace it with a known one that works for sure.
Old Apr 24, 2006 | 05:07 PM
won;t the fuel pump just cut out on you? the main realy is fine
Old Apr 24, 2006 | 08:54 PM
statik121's Avatar
relays go bad all the time. they are mechanical devices and do wear out. Especially if your is original, Honda had a huge problem back in the day with their cars dying for no reason after sitting on hot days. It was just their orignal design that sucked and they came out with an updated part. Contacts develop high resistance and reduce the amount of voltage to certain item particularly fuel pumps because they draw more current. Substitute a known good if possible and don't just rule it out.
W95civicEXcoupe
25
Sep 29, 2014 05:07 AM
KickStart2323
Mar 12, 2010 12:58 PM
watacivic
Aug 4, 2007 11:42 PM
JDMlyfestyle
19
Jan 7, 2004 08:16 PM
cr-x si
Aug 27, 2003 06:51 AM
