*Diamond Audio sub subwoofer M610D2 Audiobahn amp A8000T And enclosure*
Old Apr 16, 2006 | 02:01 PM
.Kevin.'s Avatar
Default *Diamond Audio sub subwoofer M610D2 Audiobahn amp A8000T And enclosure*
Alright well I had this same set up once before but then I had some issues with it but I liked it so much I bought the EXACT same stereo because it was so amazing. Anyway I would just like to say please research diamond audio products before you make a choice because this is not a "best buy" stereo by far. If you are local I would be more than happy to meet you and let you listen to it.
Here are the specs of the sub:
http://www.diamondaudio.com/pr...2.pdf
^^This link shows all of the specs, there are many and very detailed things so I just posted the link
Here are the specs of the amp.
Class A/B MOSFET Circuitry
PWM MOSFET Power Supply
Semi-double Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB
Frequency Response: 10Hz - 40KHz (+/- 1dB)
Variable 18dB Hi-pass Crossover: 50Hz - 750Hz
Variable 18dB Low-pass Crossover: 50Hz to 120Hz
Bass Boost On/Off
Subsonic Filter: 20Hz to 50Hz
RCA Throughput Connections
3-way Protection Circuitry: Thermal, Short Circuit and Overload; Cooling Fan
Cobalt Blue Illumination
High Gloss Chrome Plated Finish
Nickel Plated Block Terminals
Air Induction Fan Cooled
RCA and Speaker Level Inputs
800 x 1 at 4 Ohms Mono RMS!!
I do not run this amp all the way turned up, It is set at about half way and tuned for the sound overall. The enclosure was made by a stereo shop in California that I knew made good boxes. (paid 50$ to ship it to me so you know this was not a crappy box) anyway they made to to perform for this sub and only this speaker. I would like 300$ for this setup and I prefer local because this is not a light item by far (maybe 70-90 lbs.) but I will ship as long as you pay the charges. Also the set up as far as the sub and amp are maybe 4 months old with 2 months of use (sold old car and was not going to put this in a beater) and the box is two years old.
Old May 7, 2006 | 08:36 PM
.Kevin.'s Avatar
Default Re: *Diamond Audio sub subwoofer M610D2 Audiobahn amp A8000T And enclosure* (1_slow_K20)
upp
Old May 21, 2006 | 10:56 PM
slowpokecivic's Avatar
how much for just the amp...?
Old Jun 13, 2006 | 07:11 PM
.Kevin.'s Avatar
Default Re: *Diamond Audio sub subwoofer M610D2 Audiobahn amp A8000T And enclosure* (SLoWpOkECiViC)
uppp
Old Jun 14, 2006 | 07:43 PM
.Kevin.'s Avatar
uppp
Old Jun 14, 2006 | 08:26 PM
ls-v*2's Avatar
bump, ive been lusting over those amps for along time
Old Jun 14, 2006 | 09:04 PM
.Kevin.'s Avatar
Default Re: *Diamond Audio sub subwoofer M610D2 Audiobahn amp A8000T And enclosure* (shot08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shot08 &raquo;</TD></TR><TR><TD CLASS="quote">bump, ive been lusting over those amps for along time</TD></TR></TABLE>
They are really nice, I run the amp half way and it makes this sub pound!!
Old Jun 18, 2006 | 07:38 PM
.Kevin.'s Avatar
111
supracrx
Audio / Security / Video
13
May 25, 2006 12:40 PM
shutta
Jan 4, 2006 06:31 PM
ap716
Jun 30, 2005 06:09 AM
