camber kit?
Old Apr 16, 2006 | 12:02 PM
msinsky14's Avatar
Default camber kit?
my car is lowered 2.5 inches(1995 civic hatch) and I wanted to adjust the camber alignment because the tread is uneven.......what kit would be the best and how many degrees should it be adjusted on back and front?
Old Apr 16, 2006 | 12:48 PM
SVOboy's Avatar
Is your toe set properly? This will affect your wear much much more than camber.
Old Apr 16, 2006 | 12:51 PM
Neighborhood Superstar's Avatar
Default Re: camber kit? (msinsky14)
when was the last time you have an alignment? i am dropped 2" without a camber and my tires are wearing out pretty even.
Old Apr 16, 2006 | 12:52 PM
msinsky14's Avatar
Default Re: (SVOboy)
i dont think so, but is it worth it to buy adjustable cambers for handling then, and not necassarily wear, what kit would be the best to buy?
Old Apr 16, 2006 | 12:55 PM
SVOboy's Avatar
A bit of camber is better for handling, actually.
Old Apr 16, 2006 | 01:08 PM
Dublin's Avatar
What seems to be one of the popular kits is the Skunk 2 kit...I have the SPC camber kit which adjusts caster and camber and it works great (i was having the same problem)...there is no definate answer we can give you to how many degrees...best bet would be to try to eyeball it, or the recomended solution is to take it for a proper alignment...
doubleshotz
Suspension & Brakes
Nov 2, 2007 05:01 PM
00accordguy
May 21, 2006 09:33 AM
crx1009
Apr 5, 2006 09:57 AM
pr0phet
Nov 22, 2005 03:59 PM
toooslow
May 7, 2003 12:38 PM
