HELP!!! no spark
The ignitor inside the distributor might be dead. Check the bearing, and check to make sure the juice is getting to the dizzy. I've had bad plugs going from the harness to the dizzy and the spark didn't make it thru.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhatchness »</TD></TR><TR><TD CLASS="quote">did you touch any wiring at all?</TD></TR></TABLE>
what do you mean?
what do you mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Corran »</TD></TR><TR><TD CLASS="quote">Have you tried plugs and wires? Also, check for water in the plug wells, that happens some times.</TD></TR></TABLE>
havent done tthat, ill do that next. ill check for water tomarow.
if there is watter in the well, use an air nozzle to blow it out. Holding a rag at the top helps to catch it and keep it from falling back in. Dont take out the spark plug until the water is gone, hydrolocking sucks, and it doesnt take much water.
what if the light on the ecu lights up a steady red when i put the key in the #2 position and doesnt change at all?
I read somewhere that this means that the ecu is bad, is this true?
lol that happend to me.....i almost went crazy....check your main ground....it located were the top radiator hose enters the block....there should be a ground wire on the neck looking thing.....i went through 3 ecus...and i found out it was this...im an idiot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi16 »</TD></TR><TR><TD CLASS="quote">lol that happend to me.....i almost went crazy....check your main ground....it located were the top radiator hose enters the block....there should be a ground wire on the neck looking thing.....i went through 3 ecus...and i found out it was this...im an idiot</TD></TR></TABLE>
i fixed it! it starts! thanks alot
Noo_Ish_mee
Jun 27, 2016 02:44 PM
97civic07gsxr
10
Apr 6, 2009 07:16 AM
ef2 from hell
Nov 25, 2006 03:07 PM
