just baught a jdm b16a swap!!!!
Old Apr 15, 2006 | 10:10 PM
v8 integra's Avatar
Default just baught a jdm b16a swap!!!!
so i got a b16a swap.. its a obd1 engine and i have a obd1 wire harness laying around un cut..i was wondering if it would wire right up..vtec and all..also..wat kind of axles should i get...linkage?..radiator..and was a decent souding..not too loud but deep enough to hear a block away...headers to the tip...? i already orderd engine mounts and clutch cylinder..wat else would i need for this swap to be complete? thanks!
Old Apr 15, 2006 | 10:14 PM
DB1_559's Avatar
Default Re: just baught a jdm b16a swap!!!! (v8 integra)
what car is it going in
Old Apr 15, 2006 | 10:26 PM
v8 integra's Avatar
Default Re: just baught a jdm b16a swap!!!! (jdmboi86)
96 civic ex coupe
Old Apr 15, 2006 | 11:02 PM
fmrprojects's Avatar
you have to use the ex harness from your car. and then get a obd-2 distributor, injectors, and alternator. after you get that you should be ready to go. and for the axles, you can use 94-01 integra or 99-00 civic SI. same with the shift linkage
Old Apr 16, 2006 | 12:03 AM
b16egva's Avatar
You'll need to wire knock sensor, oil pressure switch, vtak...cant remember..i think theres one other thing
Old Apr 16, 2006 | 07:40 AM
v8 integra's Avatar
i dont have the ex harness...but i have a obd1 harness...
Old Apr 16, 2006 | 03:19 PM
v8 integra's Avatar
sum1 please help me!!! =[
Old Apr 16, 2006 | 03:32 PM
chodeCREW's Avatar
good luck
Old Apr 16, 2006 | 03:34 PM
Lightweight Boost's Avatar
sell the obd1 harness on ebay b/c it is useless to you
Old Apr 16, 2006 | 03:37 PM
v8 integra's Avatar
can sum one tell me why its useless? or wat exactly will i need...plzzzzzzzzzzzzzzzz help!!
Old Apr 16, 2006 | 04:29 PM
v8 integra's Avatar
plzzzzzzzzzz anyone!!!!
Old Apr 16, 2006 | 05:29 PM
cause its obd1 and ur car is obd 2
Old Apr 16, 2006 | 05:39 PM
b16egva's Avatar
i assume your using the JDM P30 ECU?
Old Apr 16, 2006 | 06:19 PM
likenother's Avatar
Default Re: (b16egva)
Just did this exact same swap in to the exact same car. First off, did you get a full swap from anywhere or did you just piece this whole thing togeather? I got the full swap from HMotorsOnline.com and that includes the right axels(Del Sol VTEC I believe.) Your gonna need a conversion harness OBD2a - OBD1 (JDMShit.com has em for cheap.) Integra LS linkage i believe is what you need. The radiator you have can work, you need Del Sol hoses though. Heres a link to a write up from a guy who did this exact swap.
http://hybrid.honda-perf.org/t....html
Hope this helps bro!
Old Apr 17, 2006 | 05:49 PM
v8 integra's Avatar
OMFG!!!! dude..u just made my day..hahahhahaha...u tha man! oh and i dont have a radiator..or axles...
Jdmhondaowner
Jul 17, 2014 01:59 PM
xwhitchx
Aug 27, 2009 07:06 PM
b18 hatch mike
Jun 12, 2007 05:58 PM
da_rimrocka
11
Dec 8, 2005 07:51 AM
vidanator
Jan 24, 2005 01:27 AM
