Honda S2000 Honda S2000
OEM clutch is junk... first track experience..... :(
Old Apr 15, 2006 | 05:38 PM
Agent Zero's Avatar
Default OEM clutch is junk... first track experience..... :(
https://honda-tech.com/zerothread/1595343
Tell me what yall think? I know I stink but possitive input would be great. TIA I need help with making this thing a little faster at the track. I don't give 2 ***** about street racing anymore, I am hooked on the track now.
Old Apr 15, 2006 | 05:42 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: OEM clutch is junk... first track experience..... :( (redsihatchback)
Let's hear it AP1-destroyers. I can't chime in because I launch at 4500 in an AP2 with no clutch delay and slightly spin the tires off the line. I think I netted a 2.1 the first time, running 14.2 @ 97. When I got the 60ft down to 1.9 and timed the shifts right, I made it 13.89 @99.
What you need to do is take your car to an HDPE/road course event. You'll be hooked on that for much longer than the 1/4
Old Apr 15, 2006 | 05:51 PM
Agent Zero's Avatar
Default Re: OEM clutch is junk... first track experience..... :( (ProjektSlideways)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjektSlideways &raquo;</TD></TR><TR><TD CLASS="quote">Let's hear it AP1-destroyers. I can't chime in because I launch at 4500 in an AP2 with no clutch delay and slightly spin the tires off the line. I think I netted a 2.1 the first time, running 14.2 @ 97. When I got the 60ft down to 1.9 and timed the shifts right, I made it 13.89 @99.
What you need to do is take your car to an HDPE/road course event. You'll be hooked on that for much longer than the 1/4</TD></TR></TABLE>
What do you mean clutch delay? And there aren't many road courses around my area. I would love to try it. It looks like a lot of fun and looks like I would love it, but like I said I just moved and don't know where I can find these types of events. but thanks anyways.
Old Apr 15, 2006 | 05:57 PM
* B A N N E D *
AP1's don't have to worry about that. The AP2's has that delay to help smoke the clutch I don't see what else it's there for. My diff fluid looks fine after about 4k without the delay.
Old Apr 15, 2006 | 06:35 PM
papa5murf's Avatar
6k rpm... feather the clutch out...
Old Apr 15, 2006 | 08:23 PM
x GotBoost x's Avatar
Same as slide im startin at 4500, slight spinage of the tires then my S is gone!
Like everyone is saying it takes practice and you have to have confidence in what you are doing its all mental man.
Old Apr 15, 2006 | 09:44 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjektSlideways &raquo;</TD></TR><TR><TD CLASS="quote">AP1's don't have to worry about that. The AP2's has that delay to help smoke the clutch I don't see what else it's there for. My diff fluid looks fine after about 4k without the delay.</TD></TR></TABLE>
is that an electrical delay? hydraulic?
Old Apr 15, 2006 | 09:54 PM
* B A N N E D *
Default Re: OEM clutch is junk... first track experience..... :( (Tyson)
Hydraulic 1-way bottleneck valve.
Old Apr 15, 2006 | 09:55 PM
Tyson's Avatar
interesting. so just remove the valve huh.
Old Apr 15, 2006 | 09:57 PM
* B A N N E D *
Harder than it sounds. It took me about 2 hours to do mine. The easier route is to just purchase an AP1 cylinder, swap, and bleed. I can do that in about half an hour.
Tyson's Avatar
slave or master?
Old Apr 15, 2006 | 10:04 PM
* B A N N E D *
Slave sir. The masters are the same.
Old Apr 15, 2006 | 10:07 PM
Tyson's Avatar
ok, good to know if anyone was to do an ap2 tranny swap...
Old Apr 15, 2006 | 10:09 PM
* B A N N E D *
Regarding that.. I don't think a tranny swap (AP2 tranny on an F20) would be as effective as a final gear swap, not to mention its more expensive.
Old Apr 15, 2006 | 10:10 PM
Tyson's Avatar
yeah, but, expense may not be an issue in some cases.
i like the fact tho that gears 5 and 6 are actually taller while 1-4 are short.
and no messing with speedo gear right?
Old Apr 15, 2006 | 10:17 PM
* B A N N E D *
Actually if you look at specific ratios in the manual, 1-4 is the same, and 5th and 6th is longer, but the secondary reduction ratio in the tranny is 1.2:1 vs 1:1(ap1). This gives you the impression you described, that 5/6 is the same while 1-4 got shorter.
I haven't seen an actually tranny swap up close, so I couldn't tell you. I've done a full AP2 motor/tranny swap, and that didn't require messing with the speedo gear.
Old Apr 15, 2006 | 10:22 PM
* B A N N E D *
Interesting note.. if you use an AP2 tranny with an AP1 rear end, your 5/6 gear will be longer than any other combination. 4k rpms will give you about 80-82mph vs 75.
Old Apr 15, 2006 | 10:24 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjektSlideways &raquo;</TD></TR><TR><TD CLASS="quote">Actually if you look at specific ratios in the manual, 1-4 is the same, and 5th and 6th is longer, but the secondary reduction ratio in the tranny is 1.2:1 vs 1:1(ap1). This gives you the impression you described, that 5/6 is the same while 1-4 got shorter.
yeah, thats what i understood.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjektSlideways &raquo;</TD></TR><TR><TD CLASS="quote">Interesting note.. if you use an AP2 tranny with an AP1 rear end, your 5/6 gear will be longer than any other combination. 4k rpms will give you about 80-82mph vs 75.</TD></TR></TABLE>
i figure it can only help in saving gas on the long hauls. im sure ill have enough passing power available.
i think we bogarted this thread...
Old Apr 15, 2006 | 10:35 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
i think we bogarted this thread... </TD></TR></TABLE>
Yea, I figured it would be good for at least a couple MPGs. And we didn't "bogart" ****. We filled it up with useful information.
Old Apr 16, 2006 | 10:57 AM
ITRbroham's Avatar
shit post warrior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjektSlideways &raquo;</TD></TR><TR><TD CLASS="quote"> The AP2's has that delay to help smoke the clutch </TD></TR></TABLE>
What is the AP2's clutch delay for, again?
I thought it was to save the synchros.
Old Apr 16, 2006 | 01:18 PM
* B A N N E D *
Default Re: OEM clutch is junk... first track experience..... :( (ITRbroham)
Nah man, it's there to smoke my clutch. It's not good for anything else.
itr1244
Sep 14, 2008 08:22 AM
Ding
Honda Civic (2006 - 2015)
56
Oct 3, 2006 08:24 PM
envious1320
Jul 15, 2003 01:07 AM
strils
May 11, 2002 01:51 PM
