Fresh ZC swap, blowing fuse
Old Apr 15, 2006 | 01:42 PM
D-Atk's Avatar
Default Fresh ZC swap, blowing fuse
Ok I just completed my ZC swap lastnight, went to start the car and sparks flew from the ground for the motor. No biggie we just moved it from its normal location, since then everytime I turn on the headlights the fuse for the dash and tail lights blows fuse #8. WTF is there a wire crossed somewhere? Car has been converted to OBD 1 but didn't have this problem till the swap.
Old Apr 15, 2006 | 02:28 PM
civiccrx21's Avatar
Default Re: Fresh ZC swap, blowing fuse (D-Atk)
sounds like you could have the ground and hot mixed up or just the hot making contact with metal causing it to blow the fuse , bad bulbs can also blow fuses well at least on AC electrical.
I would go through the harness check to make sure all the wires are protected, take the bulbs out see if it still blows , otherwise bust out the Helms or chiltons wiring diagram and go over everything good luck
Old Apr 17, 2006 | 04:53 PM
D-Atk's Avatar
Default Re: Fresh ZC swap, blowing fuse (civiccrx21)
Still no luck, we completely removed everything on the a/c side of the wiring and we got the dash lights to come on for a split second before the fuse blew. Anyone else got any suggestions.
-Racer X-
Jun 30, 2013 04:56 PM
allenlavoie
Apr 23, 2012 03:34 AM
killa69er
Feb 2, 2011 07:00 AM
queda
May 23, 2008 08:42 AM
2camsaam
Mar 12, 2003 03:55 AM
