1st gen vs. 2nd gen AEM EMS
Old Apr 15, 2006 | 12:56 PM
JDM B16 EK's Avatar
Default 1st gen vs. 2nd gen AEM EMS
i think this is the right form for this....
-does anyone have a picture of them side by side...i would like to see how much smaller the new one is compared to the old one.
-also, is the new one the same as the old one, but just more compact or are there new features?
-reason being i found one of both and deciding which one to buy...because obviously the 1st gen will be cheaper but im wondering if the new will be worth the extra $$$.
TIA
Old Apr 15, 2006 | 02:25 PM
JDM B16 EK's Avatar
Default Re: 1st gen vs. 2nd gen AEM EMS (JDM B16 EK)
ttt
Old Apr 15, 2006 | 02:43 PM
TrueNorthStar's Avatar
Some of the older versions have issues with some of the coil outputs. It's not a big problem unless you want to run a direct fire coil on plug setup.
Old Apr 16, 2006 | 01:28 PM
JDM B16 EK's Avatar
Default Re: 1st gen vs. 2nd gen AEM EMS (TrueNorthStar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrueNorthStar &raquo;</TD></TR><TR><TD CLASS="quote">Some of the older versions have issues with some of the coil outputs. It's not a big problem unless you want to run a direct fire coil on plug setup.</TD></TR></TABLE>
thanks for the info
anything else?
Old Apr 17, 2006 | 10:28 AM
JDM B16 EK's Avatar
Old Apr 17, 2006 | 02:31 PM
yee SERIOUS's Avatar
i'd like to know too. someone told me they're the same, it's just that the new boxes are more compact.
Old Apr 17, 2006 | 02:35 PM
D-tuned's Avatar
Default Re: (undercoverdc2)
the newer boxes are more compact, a few more available outputs, more coil outputs(4) and a few more inputs. the wiring is alittle different also. With the older style box if you wanted to run a hall effect sensor, you had to solder some resistors onto the mainboard. The newer boxes has jumpers on the mainboard you can switch between stock or an hall effect setup. thats all the differences i can see or heard of.
Old Apr 19, 2006 | 09:17 PM
JDM B16 EK's Avatar
Default Re: (D-tuned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-tuned &raquo;</TD></TR><TR><TD CLASS="quote">the newer boxes are more compact, a few more available outputs, more coil outputs(4) and a few more inputs. the wiring is alittle different also. With the older style box if you wanted to run a hall effect sensor, you had to solder some resistors onto the mainboard. The newer boxes has jumpers on the mainboard you can switch between stock or an hall effect setup. thats all the differences i can see or heard of.</TD></TR></TABLE>
what are the extra outputs for? and would you need more than 1 output?
what is the hall effect sensor?
Old Apr 19, 2006 | 09:23 PM
adictionbass's Avatar
well thats a downer... anyone want a 1000 box..?
Old Apr 19, 2006 | 11:27 PM
LeGeND4LiFe's Avatar
Default Re: (adictionbass)
Some of the new boxes also have built in UEGO sensors. All the software/programming/tuning features will be the same because you can DL the latest version (1.19 currently) and update the firmware on the 1st gen EMS.
Old Apr 20, 2006 | 03:41 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: (JDM B16 EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16 EK &raquo;</TD></TR><TR><TD CLASS="quote">
what is the hall effect sensor?</TD></TR></TABLE>
http://forum.aempower.com/forum/index.php
hatchness135
Jan 7, 2007 02:27 PM
JDM B16 EK
Apr 20, 2006 06:11 AM
twilightprotege
Sep 27, 2005 07:26 PM
Thuttle88
Sep 10, 2005 09:41 AM
