Radiator fan timer location
Old Apr 15, 2006 | 12:13 PM
aquaman6650's Avatar
Default Radiator fan timer location
95 Accord EX: I was told to pull the glove box and would see the radtior fan timer clearly marked, but can't seem to find it. Is it anywhere in this pic?
Old Apr 15, 2006 | 08:57 PM
Ross 2.0's Avatar
In a Junkyard near you.
The box behind the peice of tape.
Old Apr 16, 2006 | 05:39 AM
Default Re: (MooGoCow3)
Thank you much.
Old Apr 17, 2006 | 12:00 PM
chodu's Avatar
Default Re: Radiator fan timer location (aquaman6650)
Guys What does a Radiator Timer exactly do, because while ago my car was overheating... Just curious..
Thank
Old Apr 18, 2006 | 08:24 AM
JimBlake's Avatar
Default Re: Radiator fan timer location (chodu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chodu &raquo;</TD></TR><TR><TD CLASS="quote">Guys What does a Radiator Timer exactly do, because while ago my car was overheating... Just curious..
Thank</TD></TR></TABLE>It's actually called a fan timer module, & it controls the radiator fans. One temperature switch (usually in thermostat housing) is responsible for running the fans when the engine's running. Another temperature switch is responsible for running the fan after you turn off the engine. Even if the 2nd switch sticks 'on', the timer will turn off the fan.
Sometime before '98, Honda got rid of that system. My '98 Accord doesn't have a timer module, has only one fan switch, and the fan can't run after you turn off the engine.
Old Apr 18, 2006 | 09:03 AM
Ross 2.0's Avatar
Default Re: Radiator fan timer location (JimBlake)
looks a lot like that
Old Sep 6, 2007 | 12:57 PM
furugua's Avatar
Default Re: Radiator fan timer location (Evil Monkey)
how can I order this timer for my '94 accord ? my local dealerships has to special order it and it takes 4 days cost about $43.00 +shipping to Hawaii...any faster suggestions? aloha, wayne...
Old Apr 9, 2011 | 08:13 PM
75aces's Avatar
I just replaced my heater hose at the dizzy and the temp gauge is going hot. noticed that the fan on the air box side kicks on after the car is off. if i replace said timer, will it solve my issue?
jacollins5
Honda Civic (2001 - 2005)
Sep 17, 2016 01:02 AM
masospaghetti
Oct 21, 2014 03:35 PM
dman81
May 28, 2014 03:20 AM
JH4DB858
Jan 10, 2012 07:32 PM
OneBadVTEC
Feb 8, 2005 03:46 AM
