Radiator fan timer location
95 Accord EX: I was told to pull the glove box and would see the radtior fan timer clearly marked, but can't seem to find it. Is it anywhere in this pic?
https://i59.photobucket.com/albums/g...dai/honda1.jpg |
The box behind the peice of tape.
Re: (MooGoCow3)
Thank you much.
Re: Radiator fan timer location (aquaman6650)
Guys What does a Radiator Timer exactly do, because while ago my car was overheating... Just curious..
Thank |
Re: Radiator fan timer location (chodu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chodu »</TD></TR><TR><TD CLASS="quote">Guys What does a Radiator Timer exactly do, because while ago my car was overheating... Just curious..
Thank</TD></TR></TABLE>It's actually called a fan timer module, & it controls the radiator fans. One temperature switch (usually in thermostat housing) is responsible for running the fans when the engine's running. Another temperature switch is responsible for running the fan after you turn off the engine. Even if the 2nd switch sticks 'on', the timer will turn off the fan. Sometime before '98, Honda got rid of that system. My '98 Accord doesn't have a timer module, has only one fan switch, and the fan can't run after you turn off the engine. |
Re: Radiator fan timer location (JimBlake)
http://myspace-465.vo.llnwd.net/0066...66165465_l.jpg
looks a lot like that |
Re: Radiator fan timer location (Evil Monkey)
how can I order this timer for my '94 accord ? my local dealerships has to special order it and it takes 4 days cost about $43.00 +shipping to Hawaii...any faster suggestions? aloha, wayne...
I just replaced my heater hose at the dizzy and the temp gauge is going hot. noticed that the fan on the air box side kicks on after the car is off. if i replace said timer, will it solve my issue?
