88 four door project still in the works
Old Apr 15, 2006 | 10:45 AM
ahthisguyhere's Avatar
Default 88 four door project still in the works
so i bought the car it had a seized up motor so i put in a ls and wheels and coilovers on illuminas and did complete ls brake swap brake booster and m/c and now i was on the way to turbo and now my ls has a bad head gasket so for the same price to completely rebuild my ls i just went out and bought a b16 and ecu for 1085 shipped so imm doing some tightying up of things while the motors out
as you can see the whole subframe is out
im paintin the bay white to kleen up things a bit
still got to do the passenger side
i had welded my subframe brace to fit for short rad now im replacing back with stock cause im going full rad now believe it or not never had problems with it either
the cam seals on my motor were leaking
oil pan bolt broken and i rtved the hole to help with oil leak but it didnt work to well
and this is the result of the oil pan bolt broken it just throws oil everywhere
my b16 will be here on the 24th and it will be in at the end of the month and running again i cant wait im runnig it on my ls tranny so i cant wait to see how it does when runnin previous friends i have raced
Old Apr 15, 2006 | 11:06 AM
Default Re: 88 four door project still in the works (ahthisguyhere)
bump
Old Apr 15, 2006 | 04:01 PM
bump
Old Apr 15, 2006 | 06:25 PM
Jonknee's Avatar
Default Re: (ahthisguyhere)
Do you have pictures of the exterior.
Old Apr 15, 2006 | 09:12 PM
408wdy's Avatar
Default Re: (La-quiete)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by La-quiete &raquo;</TD></TR><TR><TD CLASS="quote">Do you have pictures of the exterior.</TD></TR></TABLE>
werd i want to see some body shots
Old Apr 15, 2006 | 10:36 PM
FOMULA91's Avatar
Default Re: (crxboyy408)
Man you have a lot of work.
Good luck.
Old Apr 16, 2006 | 05:12 AM
Old Apr 16, 2006 | 07:27 AM
Jonknee's Avatar
That's a hot car, i have two questions.
-What did it take to get that bumper on
-Which model did the front bumper come from.
Old Apr 16, 2006 | 08:34 AM
its just the 88 89 model off the four doors it just a stock bumper
Old Apr 16, 2006 | 08:43 AM
Jonknee's Avatar
I wonder if that fits my 91.
Old Apr 16, 2006 | 08:58 AM
yes but you need the part it screws too
Old Apr 16, 2006 | 09:18 AM
si0385.'s Avatar
good luck with it
post up pics of the progress
Old Apr 18, 2006 | 03:47 PM
so the engine bay is finished in painting
and here is the front subframe i drilled out the front motor mount braket it looks completely stock
i changed the outer tie rods for new ones and inner sway bushings
here is where the alternator would be and im welding in a relief so it dont hit
heres my struts with coilovers
LS_DON4500
Apr 16, 2010 05:07 PM
en00be
Feb 25, 2009 07:24 PM
7mile
Dec 27, 2007 12:44 PM
B_1_8_hatch
May 9, 2003 03:41 PM
