Supercharged four door build
Old Feb 15, 2009 | 10:30 AM
en00be's Avatar
Default Supercharged four door build
Well i put my LS on ccraigslist for 1100 and a d series (ls in car), next morning i get a text saying im coming to buy it today, so me and a few friends pull the LS
We put it in his car when he arrives and he gives me a grand cash and a d15b7.
"longshot" finds me a supercharger on craigslist
and now we are going to put the supercharger in, il be back later tonight with some info, and maybe a vid or two
Old Feb 15, 2009 | 12:30 PM
MadVTI's Avatar
Default Re: Supercharged four door build
wow ur car is cool. Iv got a harvard blue EG9! U rule!
Old Feb 15, 2009 | 05:40 PM
en00be's Avatar
ferio for sure
Old Feb 15, 2009 | 11:11 PM
en00be's Avatar
heres what we got done today
hopefully getting it in tomorrow but im sick so its kinda delaying my work ya know
Old Feb 16, 2009 | 08:53 AM
Jaker's Avatar
You might struggle to get that into the car with the blower attached. The blower pulley sits under the master cylinder, so unless you put it in from underneath, it won't go past the MC.
Old Feb 16, 2009 | 09:58 AM
en00be's Avatar
hmm guess we will see? lol
Old Feb 16, 2009 | 11:00 AM
EARLdaSQUIRREL's Avatar
official honda whore
you realize the car wont be as fast as it was with the ls right?
Old Feb 16, 2009 | 11:51 AM
en00be's Avatar
I know that im WELL aware of that, its more unique than an ls, i dont care how fast my car is
Old Feb 16, 2009 | 11:55 AM
MadVTI's Avatar
Originally Posted by en00be
ferio for sure
Good luck with it dude, keep it coming.
Old Feb 16, 2009 | 12:14 PM
en00be's Avatar
thanks
Old Feb 16, 2009 | 02:10 PM
PhantomX's Avatar
Loookin goood..... Post a Vid when ur done!
Old Feb 16, 2009 | 08:48 PM
en00be's Avatar
its done and running on no tune, Open header tho,but it runs strong and pulls hard has bad idle surge tho and it doesnt really sound the best it mightt need oil
Old Feb 17, 2009 | 11:17 AM
en00be's Avatar
its done...heres what its doing tho
Old Feb 17, 2009 | 04:47 PM
p73hatch21's Avatar
sounds like a vac leak bro... but it can be a few diffrent things.. get a can of throttle body cleaner and spray around the intake mani in sections. if you here a bog in one spot,then you have a leaky leaky!! but check that out.. also i know it sounds stupid but switch you map and tps around and see if it stops then. but what makes me think its a vac leak is my missing link for my turbo was messed up and it was doing the same thing.
Old Feb 17, 2009 | 05:29 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Get it tune after that
Old Feb 17, 2009 | 05:35 PM
98vtec's Avatar
moderator emeritus
plug in your iat sensor while your at it.
Old Feb 17, 2009 | 06:34 PM
en00be's Avatar
i plugged the iacv in
it didnt help anything idk what the deal is
Old Feb 17, 2009 | 06:48 PM
POORMANT's Avatar
was this the first start and did you wait till the fan comes on cause you have t o let radiator fluid run thrw the systen to that fast idle valve on the throttle bodielet it wrm up and fan run should stop
Old Feb 17, 2009 | 06:54 PM
98vtec's Avatar
moderator emeritus
intake air temperature sensor, not iacv. The white one you see in the video that isnt connected.
Old Feb 17, 2009 | 07:53 PM
Jaker's Avatar
You might have your IACV and your IAT plugs mixed up. They're both 2 pin plugs, and not keyed differently. I see that your CEL is on. What code is it?
Old Feb 17, 2009 | 07:55 PM
en00be's Avatar
idk man its been like that since my ls swap
BTW my fan isnt working at the moment
and my car was warm it still does that im gonna check it out tomor can i get a pic with the iacv and the iat plugs circled sorry for seeming so stupid haha im sick and dont feel like messin with this stuff
Old Feb 17, 2009 | 07:56 PM
en00be's Avatar
BTW i plugd that white one in. it made no difference
Old Feb 19, 2009 | 12:17 PM
en00be's Avatar
Fixin my idle surge ina bit, then lowering my car more and mounting my boost gauge
maybe even fixing my exhaust
Old Feb 19, 2009 | 12:46 PM
junior h.m's Avatar
cool little build,, i wanna see more :D
Old Feb 19, 2009 | 01:29 PM
98vtec's Avatar
moderator emeritus
do you still have a check engine light?
