My Del Sol Turbo D NEW for 06 56k NO
Old Apr 14, 2006 | 07:52 PM
KevronsEG's Avatar
Default My Del Sol Turbo D NEW for 06 56k NO
Hey guys just wanted to share my finshed project. Any feedback would be great. Thanks Kevron
Can see all pics here
http://kevinbomers.com/gallery...e=all
Old Apr 14, 2006 | 07:55 PM
delspool's Avatar
Default Re: My Del Sol Turbo D NEW for 06 56k NO (IAmTheRealKevron)
nice, have fun with it
ella94's Avatar
Dont know if i dig the yellow fogs but the car looks clean to me.
Paint the valve cover white and get some white silcone tubing and clean the engine up and will be lookin damn good!
Old Apr 14, 2006 | 08:30 PM
Sketch_hs's Avatar
where did you get that upper pipe with the hks ssq flange?
Old Apr 14, 2006 | 08:47 PM
portenio78's Avatar
Default Re: (Sketch_hs)
Nice. What turbo is that? Your going to run the water lines right?
Old Apr 14, 2006 | 08:48 PM
mrbsponge's Avatar
why is you clutch fluid resovoir moved out so far? was it relocated or are my eyes playin tricks on me?
was the car an auto before or something
Old Apr 15, 2006 | 04:57 AM
KevronsEG's Avatar
Default Re: (mrbsponge)
the turbo is a garret gt28rs. Yes i have the lines just makign sure motor was good before i install them. The clutch is in the same spot i just added another one for my power steering. i took it out and have it run in a loop and use that to keep level good.
Kevron
Old Apr 15, 2006 | 05:14 AM
drintegra's Avatar
Nice street setup I like it
Old Apr 15, 2006 | 05:18 AM
JDM00SI's Avatar
Default Re: (ella94)
Old Apr 15, 2006 | 07:33 AM
USDM 4G VTEC's Avatar
congrats
enjoy
boosting is soo addictive
so get used to fill the tank often
Old Apr 15, 2006 | 09:01 AM
nerdsports's Avatar
nice setup. let us know your dyno and/or track numbers.
one question, how do you have your catchcan lines routed?? where do they go??
Old Apr 15, 2006 | 01:42 PM
Reiketsukan's Avatar
Default Re: My Del Sol Turbo D NEW for 06 56k NO (nerdsports)
Nice and clean!! That's a different color for your valve cover, but whatever
floats your boat!
What intercooler is that? Did it take much hacking behind the bumber to get it to fit? I got an amazing deal on a greddy intercooler kit and I was wondering if there were any fitment issues for installing FMICs on a Sol.
Also, where do you have your lines going on your catch-can setup there?
Thanks.
Old Apr 15, 2006 | 02:46 PM
KevronsEG's Avatar
Default Re: My Del Sol Turbo D NEW for 06 56k NO (Reiketsukan)
I bought the intercooler form a buddy, i cant remember what brand to be exact. The valve cover color is all a story told here https://honda-tech.com/zerothread?id=1004204
The catch can is pretty easy, i took out the pcv system. Used the one port from the black box and ran it to the can and i drilled added another port from another black box and ran that line to the can also. D's dont have the two spots like B's do so i just came up with soemthing.
Old Apr 15, 2006 | 03:15 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAmTheRealKevron &raquo;</TD></TR><TR><TD CLASS="quote">
The catch can is pretty easy, i took out the pcv system. Used the one port from the black box and ran it to the can and i drilled added another port from another black box and ran that line to the can also. D's dont have the two spots like B's do so i just came up with soemthing.</TD></TR></TABLE>
Does it work good that way? I was thinking about using a vented can like yours, but with one line going into the black box and the other going to the valve cover nipple.
Old Apr 15, 2006 | 03:42 PM
KevronsEG's Avatar
Default Re: My Del Sol Turbo D NEW for 06 56k NO (EK k kay)
i have only put few like 500 miles on everythign so far. Seems fine no oil in it yet. when i bought the can it didnt have the filter on it i bought a 1in drill bit and filter and just drilled it out and put it in there. its gotta be better than nothing you know
Kevron
Old Apr 15, 2006 | 03:51 PM
Sketch_hs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs &raquo;</TD></TR><TR><TD CLASS="quote">where did you get that upper pipe with the hks ssq flange?</TD></TR></TABLE>
Old Apr 15, 2006 | 04:40 PM
KevronsEG's Avatar
i made all my piping. i just ordered all bends from summit or jc whitney and just cut and welded where i needed them.
Kevron
Old Apr 15, 2006 | 05:20 PM
. a d a m's Avatar
Looks good man
Old Apr 15, 2006 | 05:21 PM
nerdsports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAmTheRealKevron &raquo;</TD></TR><TR><TD CLASS="quote">The catch can is pretty easy, i took out the pcv system. Used the one port from the black box and ran it to the can and i drilled added another port from another black box and ran that line to the can also. D's dont have the two spots like B's do so i just came up with soemthing.</TD></TR></TABLE>
so you have 2 black boxes behind your block?? can you elaborate or take pics? (if it isnt too much to ask)...
Old Apr 15, 2006 | 07:20 PM
Soccerking3000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports &raquo;</TD></TR><TR><TD CLASS="quote">so you have 2 black boxes behind your block?? can you elaborate or take pics? (if it isnt too much to ask)...</TD></TR></TABLE>
i think he just added another port to the box he has already and made a loop
Old Apr 16, 2006 | 07:13 AM
KevronsEG's Avatar
Default Re: My Del Sol Turbo D NEW for 06 56k NO (Soccerking3000)
yea i just added another port on the other side of the box so it breaths in two spots.
Old Apr 16, 2006 | 07:46 AM
nerdsports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">
i think he just added another port to the box he has already and made a loop</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAmTheRealKevron &raquo;</TD></TR><TR><TD CLASS="quote">yea i just added another port on the other side of the box so it breaths in two spots.</TD></TR></TABLE>
cool, thanks.
Old Apr 16, 2006 | 02:51 PM
KLeSe's Avatar
clean set up, how much ya boostin?
Old Apr 16, 2006 | 03:13 PM
redzcstandardhatch's Avatar
something different
glad to see its running well still buddy...
loved it last weekend...looked great.
i love the hx bottom end...cracks me up! haha
Old Apr 16, 2006 | 03:31 PM
American.Graffiti's Avatar
nice setup.
