My Del Sol Turbo D NEW for 06 56k NO
Hey guys just wanted to share my finshed project. Any feedback would be great. Thanks Kevron
Can see all pics here
http://kevinbomers.com/gallery...e=all
Re: (mrbsponge)
the turbo is a garret gt28rs. Yes i have the lines just makign sure motor was good before i install them. The clutch is in the same spot i just added another one for my power steering. i took it out and have it run in a loop and use that to keep level good.
Kevron
Kevron
Re: My Del Sol Turbo D NEW for 06 56k NO (IAmTheRealKevron)
nice setup. let us know your dyno and/or track numbers.
one question, how do you have your catchcan lines routed?? where do they go??
Re: My Del Sol Turbo D NEW for 06 56k NO (nerdsports)
Nice and clean!! That's a different color for your valve cover, but whatever
floats your boat!
What intercooler is that? Did it take much hacking behind the bumber to get it to fit? I got an amazing deal on a greddy intercooler kit and I was wondering if there were any fitment issues for installing FMICs on a Sol.
Also, where do you have your lines going on your catch-can setup there?
Thanks.
floats your boat!
Thanks.
Re: My Del Sol Turbo D NEW for 06 56k NO (Reiketsukan)
I bought the intercooler form a buddy, i cant remember what brand to be exact. The valve cover color is all a story told here https://honda-tech.com/zerothread?id=1004204
The catch can is pretty easy, i took out the pcv system. Used the one port from the black box and ran it to the can and i drilled added another port from another black box and ran that line to the can also. D's dont have the two spots like B's do so i just came up with soemthing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAmTheRealKevron »</TD></TR><TR><TD CLASS="quote">
The catch can is pretty easy, i took out the pcv system. Used the one port from the black box and ran it to the can and i drilled added another port from another black box and ran that line to the can also. D's dont have the two spots like B's do so i just came up with soemthing.</TD></TR></TABLE>
Does it work good that way? I was thinking about using a vented can like yours, but with one line going into the black box and the other going to the valve cover nipple.
Re: My Del Sol Turbo D NEW for 06 56k NO (EK k kay)
i have only put few like 500 miles on everythign so far. Seems fine no oil in it yet. when i bought the can it didnt have the filter on it i bought a 1in drill bit and filter and just drilled it out and put it in there. its gotta be better than nothing you know
Kevron
Kevron
Re: (Sketch_hs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sketch_hs »</TD></TR><TR><TD CLASS="quote">where did you get that upper pipe with the hks ssq flange?</TD></TR></TABLE>
Re: (Sketch_hs)
i made all my piping. i just ordered all bends from summit or jc whitney and just cut and welded where i needed them.
Kevron
Kevron
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAmTheRealKevron »</TD></TR><TR><TD CLASS="quote">The catch can is pretty easy, i took out the pcv system. Used the one port from the black box and ran it to the can and i drilled added another port from another black box and ran that line to the can also. D's dont have the two spots like B's do so i just came up with soemthing.</TD></TR></TABLE>
so you have 2 black boxes behind your block?? can you elaborate or take pics? (if it isnt too much to ask)...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports »</TD></TR><TR><TD CLASS="quote">so you have 2 black boxes behind your block?? can you elaborate or take pics? (if it isnt too much to ask)...</TD></TR></TABLE>
i think he just added another port to the box he has already and made a loop
Re: My Del Sol Turbo D NEW for 06 56k NO (Soccerking3000)
yea i just added another port on the other side of the box so it breaths in two spots.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">
i think he just added another port to the box he has already and made a loop</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAmTheRealKevron »</TD></TR><TR><TD CLASS="quote">yea i just added another port on the other side of the box so it breaths in two spots.</TD></TR></TABLE>
cool, thanks.
cool, thanks.
