Swap to a DX or Si Gauge Cluster
Old Apr 14, 2006 | 06:47 PM
Deviation's Avatar
Default Swap to a DX or Si Gauge Cluster
I've got a 91 Civic hatch std. Its got a D16B2 in it now. I'm about to swap in a PM5 ecu. Can I swap in a DX cluster? I assume I can, but what's involved? Any wiring changes? Also I saw that some clusters on ebay are listed as 88-89 and some as 90-91. Is there a difference?
Thanks.
Old Apr 14, 2006 | 07:22 PM
sauceja's Avatar
Default Re: Swap to a DX or Si Gauge Cluster (Deviation)
From what I have gathered they are. I have a si cluster sitting around. i am putting it into a 88 but I think the cluster is from 90. I haven't found out for sure.
Old Apr 14, 2006 | 08:26 PM
crxnj's Avatar
Default Re: Swap to a DX or Si Gauge Cluster (sauceja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deviation &raquo;</TD></TR><TR><TD CLASS="quote">I've got a 91 Civic hatch std. Its got a D16B2 in it now. I'm about to swap in a PM5 ecu. Can I swap in a DX cluster? I assume I can, but what's involved? Any wiring changes? Also I saw that some clusters on ebay are listed as 88-89 and some as 90-91. Is there a difference?
Thanks.</TD></TR></TABLE>
D15b2..and yeah that cluster will work as long as its 90-91,,but why would you want to swap in a civic dx cluster? If anything swap in an si cluster or crx dx so you can have the tachometer..
Old Apr 14, 2006 | 10:33 PM
ndondahows's Avatar
i have a plug and play cluster with tach that will work for 50 bucks
Old Apr 15, 2006 | 04:30 AM
Deviation's Avatar
Default Re: Swap to a DX or Si Gauge Cluster (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
Good point. Just seemed harder to find an Si cluster. So no wiring changes eh? That's a plus.
ndondahows, that might be a little high. Seems like they go for $30-40 on ebay. If I can't come across one there, I'll hit you up. BTW, how many miles on the odometer?
Old Apr 15, 2006 | 05:56 AM
Floored's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deviation &raquo;</TD></TR><TR><TD CLASS="quote">Good point. Just seemed harder to find an Si cluster. So no wiring changes eh? That's a plus.
ndondahows, that might be a little high. Seems like they go for $30-40 on ebay. If I can't come across one there, I'll hit you up. BTW, how many miles on the odometer?</TD></TR></TABLE>
Don't worry about the mileage. You can swap the speedo form your old cluster to the new. As for the price it should be pretty easy to find one for 35-45. I found an SI cluster on here for 45 shipped. Post in the classified section.
And there are no wiring changes as long as you get a cluster from a 90-91 civic. Otherwise IT WILL NOT CONNECT without doing a lot of wiring.
Old Apr 15, 2006 | 06:58 AM
Deviation's Avatar
Default Re: Swap to a DX or Si Gauge Cluster (Floored)
I keep seeing 88-91 gauge clusters. What am I missing? I found one on H-T here http://hondamarketplace.com/zerothread?id=1591440 . Says 88-91. Have to excuse my ignorance on this one. I haven't seen what the Si cluster actually looks like so I'm not sure what I'm looking for.
Old Apr 15, 2006 | 07:07 AM
crxnj's Avatar
They probably dont realize it,,alot of people assume 88-91 everything is the same..Just ask the seller what year it came out of ..
Heres what a 90-91 si cluster looks like..
Old Apr 15, 2006 | 08:45 AM
sauceja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">They probably dont realize it,,alot of people assume 88-91 everything is the same..Just ask the seller what year it came out of ..
Yes but the 88-89 clusters look like this as well the only difference is in the back where everything connects. And this is the problem I found. I bought a 88-91 a while back before I researched (I am an idiot) I have an 88 and don't think mine will work.
Also having an 88 dx the clutch is different than 89-91. so upgrading requires more parts.
Setting the mileage back on these clusters is fairly easy as well from what I have heard. So the mileage shown is not a big deal and can be set back to zero.
Just my 0.02
Old Apr 15, 2006 | 08:49 AM
Deviation's Avatar
Thanks for the pic and info!
I'll keep on searching for them... well can't really search here at the moment...
Old Apr 15, 2006 | 09:04 AM
Blanket Jackson's Avatar
So that cluster pictured above WILL NOT plug into my 88 Sedan DX? I am going to pick up an 88-91 Civic Si cluster here in a little while, so I need to know as soon as possible.
Old Apr 15, 2006 | 09:14 AM
d15hatch's Avatar
Default Re: (Blanket Jackson)
This is the same problem I ran into.
I parted out my 1989 Civic LX cluster, which is the same as pictured, and went to place it in the 1990 DX hatch, all plugged in perfect, but alas, no tach, and you hit the high beams-all the idiot lamps light up.
How is the wiring different, and does anybody have the diagrams onhow to re-pin the connectors??
Old Apr 15, 2006 | 10:04 AM
Deviation's Avatar
Guess I sparked some interest in this thread.
To sum it up.....
88-89 - Fit 88-89
90-91 - Fit 90-91
I looked at the LX clusters, but I figured they wouldn't work. So I'm still pursuing an Si one for now.
Old Apr 15, 2006 | 10:09 AM
wood 1's Avatar
Default Re: (Deviation)
Deviation,
There is a thread talking about this subject but I don't know how to tell you what it so I will bump it. Hope this thread helps explain the differences in the clusters.
Old Apr 15, 2006 | 10:34 AM
sauceja's Avatar
I have an SI one but I believe it is for the 90-91 and I need one for the 88-89 so as soon as I figure out if mine will work I may have one for sale. I paid like 50.00 shipped for it with 145k on the clock.
Old Apr 15, 2006 | 10:48 AM
Deviation's Avatar
Default Re: (wood 1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wood 1 &raquo;</TD></TR><TR><TD CLASS="quote">Deviation,
There is a thread talking about this subject but I don't know how to tell you what it so I will bump it. Hope this thread helps explain the differences in the clusters.</TD></TR></TABLE>
Appreciated. The search was (and still is) down when I posted this. Otherwise I would've used it.
Old Apr 15, 2006 | 02:54 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deviation &raquo;</TD></TR><TR><TD CLASS="quote">Guess I sparked some interest in this thread.
To sum it up.....
88-89 - Fit 88-89
90-91 - Fit 90-91
I looked at the LX clusters, but I figured they wouldn't work. So I'm still pursuing an Si one for now.</TD></TR></TABLE>
Well not all the time for 88/89..Since there were 2 different companys that made the cluster in I think 89 only..
Old Apr 15, 2006 | 06:05 PM
Deviation's Avatar
Default Re: (Mr.speaker)
Well not all the time for 88/89..Since there were 2 different companys that made the cluster in I think 89 only..</TD></TR></TABLE>
This keeps getting more and more complex.... lol
Old Apr 15, 2006 | 06:35 PM
sauceja's Avatar
And so the plot thickens,
BTW the search button seems to working again for all interested.
Wuffer
Jul 30, 2007 05:14 PM
aaronblake98
Mar 15, 2004 07:01 PM
element_1one
Jun 3, 2003 09:08 AM
Kyo Babic
Jan 6, 2003 05:08 PM
serious
Apr 14, 2002 10:39 AM
