Radiator help!!!!
I have a 94 civic with a b16 my radiator has a crack so I went to discount to buy another 1 and it looks exactly the same except the inlet on mine is 1 1/4 and the discount 1 is 1 1/8 and its the same on all yr civics...I tried to just tighten the clamp tighter but it still leaked.... Help!!!!!
I even ordered radiator hoses from a 99 civic SI and the upper hose was 1 1/4 and the lower was 1 1/8 inle and my motor has both 1 1/4 on motor side and they sell me a radiator that is 1 1/8 on upper and lower WTF!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZipTieGuy »</TD></TR><TR><TD CLASS="quote">i guess you can get a smaller hose since you already bought a raditor.</TD></TR></TABLE>no I cant cause it would have to b different sizes on each side of the hose...1 1/4 motor side 1 1/8 radiator side
my roommate did something like that for his swap (it was temporary but it worked)
He took a piece of the smaller hose and slipped it over the radiator fitting and then put the bigger hose over the smaller hose and it worked! But like I said it was only temporary
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wheelmanbg »</TD></TR><TR><TD CLASS="quote">my roommate did something like that for his swap (it was temporary but it worked)
He took a piece of the smaller hose and slipped it over the radiator fitting and then put the bigger hose over the smaller hose and it worked! But like I said it was only temporary</TD></TR></TABLE>I might try that, but ima go to autzone and c if there radiator is the same inlet, I think discount sucks IMO
Man I had the same problem with Autozone, I gave up and went to Honda and bought a radiator for a civic si. It cost about $225 but I went back to Autozone 4 times and they still couldnt get it right, with the radiator or hoses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93Civac »</TD></TR><TR><TD CLASS="quote">Man I had the same problem with Autozone, I gave up and went to Honda and bought a radiator for a civic si. It cost about $225 but I went back to Autozone 4 times and they still couldnt get it right, with the radiator or hoses.</TD></TR></TABLE>maybe I should try napa they never did me wrong
I may live in the middle of nowhere but we have a carquest here and it's the best when it comes to Honda parts. Even the Honda delear sent me there once
BTW we don't have an autozone or discount auto...
its pretty damn simple solution get some rad hose clamps and just tighten the pissoutta them so they are tight against the rad inlet i did this when i had my stock civic rad with my b18b swap. i never had a problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civichatch1 »</TD></TR><TR><TD CLASS="quote">its pretty damn simple solution get some rad hose clamps and just tighten the pissoutta them so they are tight against the rad inlet i did this when i had my stock civic rad with my b18b swap. i never had a problem</TD></TR></TABLE>I tried that they still leaked....NEXT
SilvrCiv99
Aug 2, 2009 10:07 AM
streetracerof06
Feb 13, 2006 01:14 PM
dawrenn
Aug 12, 2005 06:02 AM
