'00 si motor swap to a '92 cx hatch
Old Apr 6, 2002 | 03:42 PM
DRAGLS's Avatar
Default '00 si motor swap to a '92 cx hatch
I have a '00 si motor I am swapping into a 92 cx hatch civic I noticed on the si motor there is a crank sensor do i need to do anything w/ that or do i just swap in a diff distributor and can i use the stock cx wiring harness and just run the other wires.
Old Apr 6, 2002 | 08:41 PM
poison's Avatar
Default Re: '00 si motor swap to a '92 cx hatch (DRAGLS)
i'd just add the wire to your stock wiring harness, alot more cost effective, but a lil more of a pain in the ***......ur pick
or if you can find it, use del sol vtec or 94-95 GSR distributor with OBD1 ecu.
taht would be better in the long run
Old Apr 7, 2002 | 06:23 AM
rainforest's Avatar
Default Re: '00 si motor swap to a '92 cx hatch (poison)
i say the obd1 dist. and just un plug the crank angle sensor from the oil pump. and just get the obd 1 dist and wire it. its less confusing.
Old Apr 7, 2002 | 04:55 PM
DRAGLS's Avatar
another question can i use the cx shift linkage or do i need the si linkage.
Old Apr 8, 2002 | 01:06 PM
jdmekcivic2eg's Avatar
NOPE.. you are going to need the linkage too.. try to get everything.
bebegyrll41
Aug 29, 2005 06:25 PM
slowhatch4now
Sep 15, 2003 11:02 AM
80884
Jul 31, 2003 07:47 PM
DETROITREX
Feb 25, 2002 10:19 AM
ysrhatch
Jan 19, 2002 10:37 PM
